주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fosera Scandle 200 Solar Panel Replacement
필요한 것
    1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: 1 단계, 이미지 1개 중 1개
      • Open the case by pulling the back tab toward you in a downward motion.
      댓글 쓰기
    2. Fosera Scandle 200 Solar Panel Replacement: 2 단계, 이미지 1개 중 1개
      • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
      댓글 쓰기
    3. Fosera Scandle 200 Solar Panel Replacement: 3 단계, 이미지 1개 중 1개
      • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
      댓글 쓰기
    4. Fosera Scandle 200 Solar Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
      댓글 쓰기
    5. Fosera Scandle 200 Solar Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
      • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Vincent C
회원 가입일: 09/23/14
134 평판
안내서 1개를 작성함
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G5
4 회원들
안내서 23개를 작성함
3가이드 댓글
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - 답글 공유
More information here.
niks adonis - 답글 공유
Go to the link.
niks adonis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 29
전체 시간: 1,023
