주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Desktop Power Button Board Replacement
필요한 것
    1. Framework Desktop Power Button Board Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Power down your Desktop: 1 단계, 이미지 3개 중 3개
      • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
      • Wait one minute before continuing to allow your Desktop to fully power down.
      • Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Remove the Left Panel: 2 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Remove the Left Panel: 2 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Remove the Left Panel: 2 단계, 이미지 3개 중 3개
      • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
      • Remove the Left Panel.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Remove the Right Panel: 3 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Remove the Right Panel: 3 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Remove the Right Panel: 3 단계, 이미지 3개 중 3개
      • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
      • Remove the Right Panel.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Remove the Front Panel: 4 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Remove the Front Panel: 4 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Remove the Front Panel: 4 단계, 이미지 3개 중 3개
      • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
      댓글 쓰기
    2. Framework Desktop Power Button Board Replacement, Remove the top plate screws: 5 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Remove the top plate screws: 5 단계, 이미지 2개 중 2개
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
      댓글 쓰기
    3. Framework Desktop Power Button Board Replacement, Remove the top plate: 6 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Remove the top plate: 6 단계, 이미지 2개 중 2개
      • Lift the top plate off the Desktop and remove it.
      댓글 쓰기
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: 7 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Desktop: 7 단계, 이미지 2개 중 2개
      • Rotate the Desktop onto its right side so the Mainboard is facing upward.
      댓글 쓰기
    5. Framework Desktop Power Button Board Replacement, Disconnect the power button: 8 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Disconnect the power button: 8 단계, 이미지 2개 중 2개
      • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
      댓글 쓰기
    6. Framework Desktop Power Button Board Replacement, Reroute the power button cable: 9 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reroute the power button cable: 9 단계, 이미지 2개 중 2개
      • Pull the power button cable out of its rubber clips in the chassis.
      댓글 쓰기
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: 10 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Desktop: 10 단계, 이미지 2개 중 2개
      • Rotate the Desktop so it sits upright.
      댓글 쓰기
    8. Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: 11 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: 11 단계, 이미지 2개 중 2개
      • Use your Framework Desktop Screwdriver to remove the two 4.5 mm‑long screws securing the Power Button Board.
      댓글 쓰기
    9. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: 12 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: 12 단계, 이미지 2개 중 2개
      • Use your finger to pull the Power Button Board off its alignment peg.
      댓글 쓰기
    10. Framework Desktop Power Button Board Replacement, Remove the Power Button Board: 13 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Remove the Power Button Board: 13 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Remove the Power Button Board: 13 단계, 이미지 3개 중 3개
      • Pull the Power Button Board away from the Desktop, threading its cable through the chassis.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Disassembly complete: 14 단계, 이미지 1개 중 1개
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Place the Power Button Board: 15 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Place the Power Button Board: 15 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Place the Power Button Board: 15 단계, 이미지 3개 중 3개
      • Insert the Power Button Board cable into the slot in the Desktop.
      • Grip the cable from the top of the Desktop and thread it through the chassis.
      댓글 쓰기
    2. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: 16 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: 16 단계, 이미지 2개 중 2개
      • Place the board into its slot in the Desktop so the alignment peg is threaded through its hole in the board.
      댓글 쓰기
    3. Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: 17 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: 17 단계, 이미지 2개 중 2개
      • Use your Framework Desktop Screwdriver to install the two 4.5 mm‑long screws securing the Power Button Board.
      댓글 쓰기
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: 18 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Desktop: 18 단계, 이미지 2개 중 2개
      댓글 쓰기
    5. Framework Desktop Power Button Board Replacement, Reroute the power button cable: 19 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reroute the power button cable: 19 단계, 이미지 2개 중 2개
      • Press the power button cable into its rubber clips in the chassis.
      댓글 쓰기
    6. Framework Desktop Power Button Board Replacement, Connect the power button: 20 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Connect the power button: 20 단계, 이미지 2개 중 2개
      • Slide the power button cable over the nine-pronged connector on the Mainboard.
      댓글 쓰기
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: 21 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Reposition the Desktop: 21 단계, 이미지 2개 중 2개
      댓글 쓰기
    8. Framework Desktop Power Button Board Replacement, Place the top plate: 22 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Place the top plate: 22 단계, 이미지 2개 중 2개
      • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
      댓글 쓰기
    9. Framework Desktop Power Button Board Replacement: 23 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement: 23 단계, 이미지 2개 중 2개
      • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
      댓글 쓰기
    10. Framework Desktop Power Button Board Replacement, Install the top plate screws: 24 단계, 이미지 2개 중 1개 Framework Desktop Power Button Board Replacement, Install the top plate screws: 24 단계, 이미지 2개 중 2개
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
      댓글 쓰기
    11. Framework Desktop Power Button Board Replacement, Install the Front Panel: 25 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Install the Front Panel: 25 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Install the Front Panel: 25 단계, 이미지 3개 중 3개
      • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
      • Press the Front Panel flat to the chassis and let it align to the magnets.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Install the Right Panel: 26 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Install the Right Panel: 26 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Install the Right Panel: 26 단계, 이미지 3개 중 3개
      • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Right Panel and the silver base.
      • Push the Right Panel towards the base of the computer to engage the clips.
      댓글 쓰기
    1. Framework Desktop Power Button Board Replacement, Install the Left Panel: 27 단계, 이미지 3개 중 1개 Framework Desktop Power Button Board Replacement, Install the Left Panel: 27 단계, 이미지 3개 중 2개 Framework Desktop Power Button Board Replacement, Install the Left Panel: 27 단계, 이미지 3개 중 3개
      • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Left Panel and the silver base.
      • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
      댓글 쓰기
결론
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
247,516 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 61
전체 시간: 580
