주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Framework Laptop 12 Fastener Guide
필요한 것
  1. Framework Laptop 12 Fastener Guide, Fasteners information: 1 단계, 이미지 2개 중 1개 Framework Laptop 12 Fastener Guide, Fasteners information: 1 단계, 이미지 2개 중 2개
    • The Fastener Kit contains the following:
    • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
    • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
    • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
    • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
    • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
    댓글 쓰기
  2. Framework Laptop 12 Fastener Guide, Antenna screws: 2 단계, 이미지 3개 중 1개 Framework Laptop 12 Fastener Guide, Antenna screws: 2 단계, 이미지 3개 중 2개 Framework Laptop 12 Fastener Guide, Antenna screws: 2 단계, 이미지 3개 중 3개
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
    댓글 쓰기
  3. Framework Laptop 12 Fastener Guide, Display screws: 3 단계, 이미지 2개 중 1개 Framework Laptop 12 Fastener Guide, Display screws: 3 단계, 이미지 2개 중 2개
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
    댓글 쓰기
  4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 4 단계, 이미지 3개 중 1개 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 4 단계, 이미지 3개 중 2개 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 4 단계, 이미지 3개 중 3개
    • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
    • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
    댓글 쓰기
  5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 5 단계, 이미지 3개 중 1개 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 5 단계, 이미지 3개 중 2개 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 5 단계, 이미지 3개 중 3개
    • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
    댓글 쓰기
  6. Framework Laptop 12 Fastener Guide, Hinge screws (top): 6 단계, 이미지 3개 중 1개 Framework Laptop 12 Fastener Guide, Hinge screws (top): 6 단계, 이미지 3개 중 2개 Framework Laptop 12 Fastener Guide, Hinge screws (top): 6 단계, 이미지 3개 중 3개
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
    댓글 쓰기
  7. Framework Laptop 12 Fastener Guide, Power Button screw: 7 단계, 이미지 2개 중 1개 Framework Laptop 12 Fastener Guide, Power Button screw: 7 단계, 이미지 2개 중 2개
    • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
    댓글 쓰기
  8. Framework Laptop 12 Fastener Guide, SSD clip screw: 8 단계, 이미지 2개 중 1개 Framework Laptop 12 Fastener Guide, SSD clip screw: 8 단계, 이미지 2개 중 2개
    • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
    댓글 쓰기
  9. Framework Laptop 12 Fastener Guide, Touchpad screws: 9 단계, 이미지 3개 중 1개 Framework Laptop 12 Fastener Guide, Touchpad screws: 9 단계, 이미지 3개 중 2개 Framework Laptop 12 Fastener Guide, Touchpad screws: 9 단계, 이미지 3개 중 3개
    • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
    댓글 쓰기
  10. Framework Laptop 12 Fastener Guide, Webcam screws: 10 단계, 이미지 2개 중 1개 Framework Laptop 12 Fastener Guide, Webcam screws: 10 단계, 이미지 2개 중 2개
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
    댓글 쓰기
결론
If you need help, contact Framework support.
취소: 해당 안내서를 완성하지 않았습니다.
Arthur Shi
회원 가입일: 01/03/18
337,114 평판
안내서 849개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 50
전체 시간: 235
