주요 콘텐츠로 건너뛰기
FujiFilm FinePix XP50 Motherboard Replacement
필요한 것
  1. FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: 1 단계, 이미지 1/3 FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: 1 단계, 이미지 2/3 FujiFilm FinePix XP50 Motherboard  Replacement, Rear Case: 1 단계, 이미지 3/3
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. FujiFilm FinePix XP50 Motherboard  Replacement: 2 단계, 이미지 1/3 FujiFilm FinePix XP50 Motherboard  Replacement: 2 단계, 이미지 2/3 FujiFilm FinePix XP50 Motherboard  Replacement: 2 단계, 이미지 3/3
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. FujiFilm FinePix XP50 Motherboard  Replacement: 3 단계, 이미지 1/1
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. FujiFilm FinePix XP50 Motherboard  Replacement: 4 단계, 이미지 1/3 FujiFilm FinePix XP50 Motherboard  Replacement: 4 단계, 이미지 2/3 FujiFilm FinePix XP50 Motherboard  Replacement: 4 단계, 이미지 3/3
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. FujiFilm FinePix XP50 Motherboard  Replacement: 5 단계, 이미지 1/3 FujiFilm FinePix XP50 Motherboard  Replacement: 5 단계, 이미지 2/3 FujiFilm FinePix XP50 Motherboard  Replacement: 5 단계, 이미지 3/3
  6. FujiFilm FinePix XP50 Motherboard  Replacement: 6 단계, 이미지 1/3 FujiFilm FinePix XP50 Motherboard  Replacement: 6 단계, 이미지 2/3 FujiFilm FinePix XP50 Motherboard  Replacement: 6 단계, 이미지 3/3
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
  7. FujiFilm FinePix XP50 Motherboard  Replacement, Motherboard: 7 단계, 이미지 1/1
    • Using Phillips #00 screwdriver, remove four 3.0 mm screws holding motherboard in place.
  8. FujiFilm FinePix XP50 Motherboard  Replacement: 8 단계, 이미지 1/1
    • Insert the spudger in between the side case pannel and the motherboard.
    • Move the spudger in an upward motion to pry the motherboard out of the plastic housing. Work all the way around the motherboard until the motherboard is free.
  9. FujiFilm FinePix XP50 Motherboard  Replacement: 9 단계, 이미지 1/2 FujiFilm FinePix XP50 Motherboard  Replacement: 9 단계, 이미지 2/2
    • There are four wires that are soldered to the motherboard. Detach these wires from the motherboard by desoldering them.This will free the motherboard.
    • For instructions on desoldering see How To Solder and Desolder Connections
결론
다른 2명이 해당 안내서를 완성하였습니다.
Catherine Daniel
회원 가입일: 03/20/15
396 평판
안내서 3개 작성하였습니다
Baylor, Team 2-4, Grigsby Spring 2015 Baylor, Team 2-4, Grigsby Spring 2015 회원
BU-GRIGSBY-S15S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 1,509
