주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm FinePix F505EXR Selector Button Replacement
필요한 것
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Power the device down before taking any other actions.
      • Hold the camera with the lens facing towards youself.
      • Turn the camera upside down and place your right thumb on the battery chamber cover.
      댓글 쓰기
    2. Fujifilm FinePix F505EXR Selector Button Replacement: 2 단계, 이미지 2개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement: 2 단계, 이미지 2개 중 2개
      • Hold the camera, then pull the battery chamber towards yourself with your right thumb.
      • Pull the cover entirely out and release it to reveal the battery.
      댓글 쓰기
    3. Fujifilm FinePix F505EXR Selector Button Replacement: 3 단계, 이미지 2개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the orange battery latch that holds the battery in place.
      • Use your finger to push the latch away from yourself to release the battery.
      • Remove the battery manually from the battery chamber.
      • Place the battery into a charger if it is dead.
      • Remove battery before performing any other repairs.
      댓글 쓰기
      • Replace defective battery if previous steps fail
      • Contact support on the Fujifilm website for further assistance
      댓글 쓰기
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: 5 단계, 이미지 3개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: 5 단계, 이미지 3개 중 2개 Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button Circuit Board: 5 단계, 이미지 3개 중 3개
      • Remove four 2.5mm Phillips #1 screws on the bottom of the camera near where the camera mount attaches.
      • Remove two 5.1mm Phillips #1 screws on the left side of the camera relative to the LCD screen.
      • Remove two 5.1mm Phillips #1 screws on the right side of the camera relative to the LCD screen nearest to the mode wheel.
      댓글 쓰기
    2. Fujifilm FinePix F505EXR Selector Button Replacement: 6 단계, 이미지 2개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Place the camera lens face down with the LCD screen face up on a flat surface, or hold it. Carefully lift the camera’s back cover approximately 1 inch.
      • Carefully lift the ribbon clamp connector back using the tweezers and remove the blue ribbon.
      • Do NOT pull on ribbon if the ribbon clamp connector still grasps the blue ribbon. This could cause severe damage to the ribbon.
      • If you are replacing the LCD monitor you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the LCD monitor repair guide.
      • If you are replacing the Mode Dial you can skip steps 6 and 7 for the selector button circuit board guide and go directly to the Mode Dial repair guide.
      댓글 쓰기
    3. Fujifilm FinePix F505EXR Selector Button Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the back of the camera case and place it on a flat surface with the selector button circuit board facing up.
      • Remove the three 3.5mm Phillips #1 screws located on the chip seen in the image.
      댓글 쓰기
    4. Fujifilm FinePix F505EXR Selector Button Replacement: 8 단계, 이미지 3개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement: 8 단계, 이미지 3개 중 2개 Fujifilm FinePix F505EXR Selector Button Replacement: 8 단계, 이미지 3개 중 3개
      • Lift the chip with tweezers to remove it from the other remaining components.
      댓글 쓰기
    1. Fujifilm FinePix F505EXR Selector Button Replacement, Selector Button: 9 단계, 이미지 1개 중 1개
      • After the selector button circuit board is taken out. There will be a black rubber display for the front buttons, remove this.
      댓글 쓰기
    2. Fujifilm FinePix F505EXR Selector Button Replacement: 10 단계, 이미지 2개 중 1개 Fujifilm FinePix F505EXR Selector Button Replacement: 10 단계, 이미지 2개 중 2개
      • After taking the rubber button selector out, there will still be a circular metal selector button. This is what makes the camera delete pictures and do various tasks. Remove this and set aside.
      댓글 쓰기
    3. Fujifilm FinePix F505EXR Selector Button Replacement: 11 단계, 이미지 1개 중 1개
      • Finally replace the selector button with the new replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brittany Perkins
회원 가입일: 03/20/17
310 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 UMass Dartmouth, Team S2-G6, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G6
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 664
