주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm FinePix S4200 Viewfinder Replacement
필요한 것
    1. Fujifilm FinePix S4200 Viewfinder  Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
      • Turn the camera off.
      • Turn the camera upside down so that the battery compartment is showing.
      댓글 쓰기
    2. Fujifilm FinePix S4200 Viewfinder  Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
      댓글 쓰기
    3. Fujifilm FinePix S4200 Viewfinder  Replacement: 3 단계, 이미지 1개 중 1개
      • Rotate camera to the side where the speaker ports are located.
      • Remove the three 4 mm screws with a Phillips #000 screwdriver.
      댓글 쓰기
    4. Fujifilm FinePix S4200 Viewfinder  Replacement: 4 단계, 이미지 1개 중 1개
      • Turn the camera to the opposite side where the HDMI port is located.
      • Remove all five 4 mm screws with a Phillips #000 screwdriver.
      댓글 쓰기
    5. Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 3개 중 1개 Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 3개 중 2개 Fujifilm FinePix S4200 Viewfinder  Replacement: 5 단계, 이미지 3개 중 3개
      • Casing is fragile.
      • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
      • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
      댓글 쓰기
    6. Fujifilm FinePix S4200 Viewfinder  Replacement: 6 단계, 이미지 1개 중 1개
      • Use force to pull apart the back casing from the camera.
      댓글 쓰기
    7. Fujifilm FinePix S4200 Viewfinder  Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
      댓글 쓰기
    8. Fujifilm FinePix S4200 Viewfinder  Replacement: 8 단계, 이미지 2개 중 1개 Fujifilm FinePix S4200 Viewfinder  Replacement: 8 단계, 이미지 2개 중 2개
      • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
      • Flip over LCD screen so that the left side of the metal plate is visible.
      댓글 쓰기
    9. Fujifilm FinePix S4200 Viewfinder  Replacement: 9 단계, 이미지 1개 중 1개
      • Rotate the camera vertically so that it is easier to manage.
      • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
      댓글 쓰기
    10. Fujifilm FinePix S4200 Viewfinder  Replacement: 10 단계, 이미지 1개 중 1개
      • Detach the metal plate from the motherboard.
      댓글 쓰기
    11. Fujifilm FinePix S4200 Viewfinder  Replacement: 11 단계, 이미지 2개 중 1개 Fujifilm FinePix S4200 Viewfinder  Replacement: 11 단계, 이미지 2개 중 2개
      • The orange ribbon cable is fragile.
      • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
      • Gently remove the LCD screen from the motherboard.
      댓글 쓰기
    1. Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: 12 단계, 이미지 2개 중 1개 Fujifilm FinePix S4200 Viewfinder  Replacement, Viewfinder: 12 단계, 이미지 2개 중 2개
      • Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
      댓글 쓰기
    2. Fujifilm FinePix S4200 Viewfinder  Replacement: 13 단계, 이미지 1개 중 1개
      • Carefully pull off the plastic cover from the view finder.
      댓글 쓰기
    3. Fujifilm FinePix S4200 Viewfinder  Replacement: 14 단계, 이미지 1개 중 1개
      • Remove the two 3mm screws surrounding the viewfinder with a Phillips 000 screwdriver.
      댓글 쓰기
    4. Fujifilm FinePix S4200 Viewfinder  Replacement: 15 단계, 이미지 1개 중 1개
      • Orange ribbon is fragile.
      • Using the plastic opening tool, pull down the small black latch to remove the orange ribbon from the mother board.
      댓글 쓰기
    5. Fujifilm FinePix S4200 Viewfinder  Replacement: 16 단계, 이미지 1개 중 1개
      • Pull the viewfinder up to remove it from the body of the camera
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Melissa Burciaga
회원 가입일: 09/14/15
158 평판
안내서 1개를 작성함
CSU Fullerton, Team 1-4, Bruce Fall 2015 CSU Fullerton, Team 1-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G4
4 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 1,285
