주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm FinePix S8200 LCD Screen Replacement
필요한 것
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, Batteries: 1 단계, 이미지 1개 중 1개
      • Turn the camera upside down so you can access the battery chamber.
      • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
      댓글 쓰기
    2. Fujifilm FinePix S8200 LCD Screen  Replacement: 2 단계, 이미지 1개 중 1개
      • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
      댓글 쓰기
    3. Fujifilm FinePix S8200 LCD Screen  Replacement: 3 단계, 이미지 1개 중 1개
      • With the battery chamber open, remove the old batteries.
      • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
      댓글 쓰기
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 1개 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 2개 Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: 4 단계, 이미지 3개 중 3개
      • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
      댓글 쓰기
    2. Fujifilm FinePix S8200 LCD Screen  Replacement: 5 단계, 이미지 3개 중 1개 Fujifilm FinePix S8200 LCD Screen  Replacement: 5 단계, 이미지 3개 중 2개 Fujifilm FinePix S8200 LCD Screen  Replacement: 5 단계, 이미지 3개 중 3개
      • Carefully pry away the rear housing cover with the plastic opening tool.
      댓글 쓰기
    3. Fujifilm FinePix S8200 LCD Screen  Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the rear housing cover by carefully pulling it away from the camera.
      댓글 쓰기
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
      • Fold back the LCD screen with the plastic opening tool.
      • Remove the cable coming from the LCD screen that goes into the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joseph Kelley
회원 가입일: 01/15/15
228 평판
안내서 2개를 작성함
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G1
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 1,633
