주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm FinePix S8630 Flash Lid Spring Replacement
필요한 것
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: 1 단계, 이미지 1개 중 1개
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      댓글 쓰기
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 2 단계, 이미지 1개 중 1개
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      댓글 쓰기
    3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 3 단계, 이미지 1개 중 1개
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      댓글 쓰기
    4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 4 단계, 이미지 2개 중 1개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 4 단계, 이미지 2개 중 2개
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      댓글 쓰기
    5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 5 단계, 이미지 1개 중 1개
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      댓글 쓰기
    6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 6 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      댓글 쓰기
    7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 7 단계, 이미지 3개 중 3개
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      댓글 쓰기
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: 8 단계, 이미지 2개 중 1개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: 8 단계, 이미지 2개 중 2개
      • Firmly grasp the flash bulb lid and remove the lid from the camera.
      댓글 쓰기
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 3개 중 1개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 3개 중 2개 Fujifilm FinePix S8630 Flash Lid Spring  Replacement: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Locate the spring and grasp with the tweezers.
      • Pinch and compress the spring to remove it from the camera housing.
      • Slide the lever that was holding the spring out of the camera housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Colton Lancsarics
회원 가입일: 02/10/16
731 평판
안내서 6개를 작성함
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 27
전체 시간: 639
