주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm Instax Mini Eight Camera Shell Replacement
필요한 것
    1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 3개 중 1개 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 3개 중 2개 Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: 1 단계, 이미지 3개 중 3개
      • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
      • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
      댓글 쓰기
    2. Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 3개 중 1개 Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 3개 중 2개 Fujifilm Instax Mini Eight Camera Shell Replacement: 2 단계, 이미지 3개 중 3개
      • Press the tab down in order to unlatch the film compartment cover.
      • Remove the film from the compartment (if any is present)
      • Remove the compartment cover completely.
      • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
      댓글 쓰기
    3. Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 3개 중 1개 Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 3개 중 2개 Fujifilm Instax Mini Eight Camera Shell Replacement: 3 단계, 이미지 3개 중 3개
      • Use the plastic opening tools and spudger to safely remove the front shell casing.
      댓글 쓰기
    4. Fujifilm Instax Mini Eight Camera Shell Replacement: 4 단계, 이미지 2개 중 1개 Fujifilm Instax Mini Eight Camera Shell Replacement: 4 단계, 이미지 2개 중 2개
      • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
      • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
      • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Bo W
회원 가입일: 10/02/12
1,052 평판
안내서 5개를 작성함
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 회원
USFT-MEIER-F15S4G1
4 회원들
안내서 31개를 작성함
19가이드 댓글
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - 답글 공유
but where near the exit? i cannot find it
Emily Birkler - 답글 공유
It's at the top of the camera where you get picture.
xxx - 답글 공유
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - 답글 공유
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 42
지난 30일: 199
전체 시간: 71,333
