주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm X30 Lens Replacement
필요한 것
    1. Fujifilm X30 Lens Replacement, Battery: 1 단계, 이미지 2개 중 1개 Fujifilm X30 Lens Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn the camera upside down.
      • Place your thumb on the switch, and slide it towards the center of the camera.
      • The compartment will pop open.
      댓글 쓰기
    2. Fujifilm X30 Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
      댓글 쓰기
    3. Fujifilm X30 Lens Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the battery out.
      댓글 쓰기
    1. Fujifilm X30 Lens Replacement, Lens: 4 단계, 이미지 3개 중 1개 Fujifilm X30 Lens Replacement, Lens: 4 단계, 이미지 3개 중 2개 Fujifilm X30 Lens Replacement, Lens: 4 단계, 이미지 3개 중 3개
      • Begin by removing the outside screws using a Phillips #000 Screwdriver:
      • Remove the three 3.6 mm silver screws located on the bottom of the camera.
      • Remove all four of the 4.7 mm screws from the sides of the camera.
      댓글 쓰기
    2. Fujifilm X30 Lens Replacement: 5 단계, 이미지 2개 중 1개 Fujifilm X30 Lens Replacement: 5 단계, 이미지 2개 중 2개
      • Remove all screws listed below using a Phillips #000 Screwdriver:
      • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
      • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
      댓글 쓰기
    3. Fujifilm X30 Lens Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully remove the bottom piece of the camera.
      댓글 쓰기
    4. Fujifilm X30 Lens Replacement: 7 단계, 이미지 1개 중 1개
      • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
      • Gently pull off the back of the camera from the left side so that it is partially open.
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
      • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
      댓글 쓰기
    5. Fujifilm X30 Lens Replacement: 8 단계, 이미지 3개 중 1개 Fujifilm X30 Lens Replacement: 8 단계, 이미지 3개 중 2개 Fujifilm X30 Lens Replacement: 8 단계, 이미지 3개 중 3개
      • For all five indicated orange strips:
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
      댓글 쓰기
    6. Fujifilm X30 Lens Replacement: 9 단계, 이미지 1개 중 1개
      • For the final orange strip located behind the top strip:
      댓글 쓰기
    7. Fujifilm X30 Lens Replacement: 10 단계, 이미지 3개 중 1개 Fujifilm X30 Lens Replacement: 10 단계, 이미지 3개 중 2개 Fujifilm X30 Lens Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the two 3.4 mm screws at the bottom of the silver plate.
      • Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
      • Peel back the copper plate.
      댓글 쓰기
    8. Fujifilm X30 Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
      • Lift the motherboard so it is out of your way to remove the lens.
      • You do not need to desolder the motherboard to reach the lens.
      댓글 쓰기
    9. Fujifilm X30 Lens Replacement: 12 단계, 이미지 1개 중 1개
      • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
      댓글 쓰기
    10. Fujifilm X30 Lens Replacement: 13 단계, 이미지 2개 중 1개 Fujifilm X30 Lens Replacement: 13 단계, 이미지 2개 중 2개
      • Pull the lens down so it can clear the silver tab.
      • Then push the lens with your index fingers from the front of the camera until it is removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Haley Moss
회원 가입일: 01/11/16
370 평판
안내서 1개를 작성함
Cal Poly, Team 70-3, Forte Winter 2016 Cal Poly, Team 70-3, Forte Winter 2016 회원
CPSU-FORTE-W16S70G3
5 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 60
전체 시간: 6,183
