주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujitsu LifeBook N3510 Fan Replacement
필요한 것
  1. Fujitsu LifeBook N3510 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the two clips on the bottom of the computer that support the battery.
    댓글 쓰기
  2. Fujitsu LifeBook N3510 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
    댓글 쓰기
  3. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: 3 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: 3 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: 3 단계, 이미지 3개 중 3개
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    댓글 쓰기
  4. Fujitsu LifeBook N3510 Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
    댓글 쓰기
  5. Fujitsu LifeBook N3510 Fan Replacement: 5 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 5 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to partially lift the hinge cover.
    댓글 쓰기
  6. Fujitsu LifeBook N3510 Fan Replacement: 6 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 6 단계, 이미지 2개 중 2개
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
    댓글 쓰기
  7. Fujitsu LifeBook N3510 Fan Replacement: 7 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    댓글 쓰기
  8. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: 8 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: 8 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Fan Replacement, Keyboard: 8 단계, 이미지 3개 중 3개
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
    댓글 쓰기
  9. Fujitsu LifeBook N3510 Fan Replacement: 9 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Use a spudger to release the ribbon cable from the motherboard.
    댓글 쓰기
  10. Fujitsu LifeBook N3510 Fan Replacement: 10 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • After the ribbon has been detached, carefully remove the keyboard.
    댓글 쓰기
  11. Fujitsu LifeBook N3510 Fan Replacement, Metal Motherboard Cover: 11 단계, 이미지 1개 중 1개
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
    댓글 쓰기
  12. Fujitsu LifeBook N3510 Fan Replacement: 12 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 12 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Lift the cover with fingers and remove.
    댓글 쓰기
  13. Fujitsu LifeBook N3510 Fan Replacement, Fan: 13 단계, 이미지 3개 중 1개 Fujitsu LifeBook N3510 Fan Replacement, Fan: 13 단계, 이미지 3개 중 2개 Fujitsu LifeBook N3510 Fan Replacement, Fan: 13 단계, 이미지 3개 중 3개
    • Detach fan cable from motherboard.
    댓글 쓰기
  14. Fujitsu LifeBook N3510 Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Remove labeled screws.
    댓글 쓰기
  15. Fujitsu LifeBook N3510 Fan Replacement: 15 단계, 이미지 2개 중 1개 Fujitsu LifeBook N3510 Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Remove fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Neil Daniels
회원 가입일: 01/17/11
1,411 평판
안내서 11개를 작성함
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G18
3 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 4,410
