주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujitsu Lifebook A6110 RAM Replacement
필요한 것
  1. Fujitsu Lifebook A6110 RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Fujitsu Lifebook A6110 RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
    댓글 쓰기
  2. Fujitsu Lifebook A6110 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
    댓글 쓰기
  3. Fujitsu Lifebook A6110 RAM Replacement, RAM: 3 단계, 이미지 2개 중 1개 Fujitsu Lifebook A6110 RAM Replacement, RAM: 3 단계, 이미지 2개 중 2개
    • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
    • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
    댓글 쓰기
  4. Fujitsu Lifebook A6110 RAM Replacement: 4 단계, 이미지 3개 중 1개 Fujitsu Lifebook A6110 RAM Replacement: 4 단계, 이미지 3개 중 2개 Fujitsu Lifebook A6110 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the cover towards the screw, and then lift the cover upwards.
    댓글 쓰기
  5. Fujitsu Lifebook A6110 RAM Replacement: 5 단계, 이미지 2개 중 1개 Fujitsu Lifebook A6110 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
    • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
    • If done correctly, the RAM card will eject at a 45 degree angle.
    댓글 쓰기
  6. Fujitsu Lifebook A6110 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
    • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
    • If you choose to replace the other RAM card, repeat the process in Step 5.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Cody Moniz
회원 가입일: 10/19/16
422 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 1,329
