주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fused LED Light Replacement
필요한 것
    1. Fused LED Light Replacement, Fused LED Light: 1 단계, 이미지 2개 중 1개 Fused LED Light Replacement, Fused LED Light: 1 단계, 이미지 2개 중 2개
      • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
      댓글 쓰기
    2. Fused LED Light Replacement: 2 단계, 이미지 3개 중 1개 Fused LED Light Replacement: 2 단계, 이미지 3개 중 2개 Fused LED Light Replacement: 2 단계, 이미지 3개 중 3개
      • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
      • The LED which doesn't lights up is detected as the faulty LED.
      댓글 쓰기
    3. Fused LED Light Replacement: 3 단계, 이미지 1개 중 1개
      • Using a knife or screwdriver, remove the faulty LED.
      • We need to replace it with a similar LED or a resistor.
      • Connecting the terminals directly can result in an increased current and multiple LED failure.
      댓글 쓰기
    4. Fused LED Light Replacement: 4 단계, 이미지 2개 중 1개 Fused LED Light Replacement: 4 단계, 이미지 2개 중 2개
      • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
      댓글 쓰기
    5. Fused LED Light Replacement: 5 단계, 이미지 1개 중 1개
      • Connect the bulb to a power source to detect if it's working.
      댓글 쓰기
    6. Fused LED Light Replacement: 6 단계, 이미지 2개 중 1개 Fused LED Light Replacement: 6 단계, 이미지 2개 중 2개
      • Finally, twist the light-diffusing dome back on the light bulb.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Abhay choudhary
회원 가입일: 05/16/21
237 평판
안내서 1개를 작성함
1가이드 댓글
I have a large LED bulb with 8 banks of LEDs. The bulb would flicker at times then stay illuminated for a period. After a short time doing this it would completely stop then come back on. It finally stopped working at all. I engineered myself a couple leads from some old multimeter leads I had collecting dusk. I attached those to a fresh 9v battery then checked each bank of LED. All illuminate as quickly as I touch the leads to the first LED in each bank. What’s the issues with this bulb? It’s not due to a bad LED and breaking the continuity. I also prior to testing with the battery went through each bank getting a solid tone so there’s no loss of power from ATo Z. I’m open to suggestions based on your experience tackling this issue. It’s my first rodeo with the LED bulb. Thanks for your help.
Farron - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 27
지난 30일: 120
전체 시간: 10,022
