주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GD Midea FT30-3D Motor Replacement
필요한 것
    1. GD Midea FT30-3D Motor Replacement, Fan Blades: 1 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement, Fan Blades: 1 단계, 이미지 2개 중 2개
      • Release the 3 clips that attach the front fan guard to the rear fan guard.
      • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
      댓글 쓰기
    2. GD Midea FT30-3D Motor Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the front fan guard off.
      댓글 쓰기
    3. GD Midea FT30-3D Motor Replacement: 3 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the spinner from the center of the fan blade.
      댓글 쓰기
    4. GD Midea FT30-3D Motor Replacement: 4 단계, 이미지 1개 중 1개
      • The fan blades should now be easy to lift up.
      • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
      댓글 쓰기
    1. GD Midea FT30-3D Motor Replacement, Oscillation Mechanism: 5 단계, 이미지 1개 중 1개
      • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
      • The plastic nut needs to be twisted off; like a screw.
      댓글 쓰기
    2. GD Midea FT30-3D Motor Replacement: 6 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
      • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
      댓글 쓰기
    3. GD Midea FT30-3D Motor Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the front motor housing by removing 4 screws.
      댓글 쓰기
    4. GD Midea FT30-3D Motor Replacement: 8 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement: 8 단계, 이미지 2개 중 2개
      • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
      댓글 쓰기
    5. GD Midea FT30-3D Motor Replacement: 9 단계, 이미지 1개 중 1개
      • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
      댓글 쓰기
    6. GD Midea FT30-3D Motor Replacement: 10 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the screw that connects the oscillator to the rocker arm.
      • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
      댓글 쓰기
    7. GD Midea FT30-3D Motor Replacement: 11 단계, 이미지 1개 중 1개
      • The oscillator should now be easy to pull off.
      • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
      댓글 쓰기
    1. GD Midea FT30-3D Motor Replacement, Motor: 12 단계, 이미지 2개 중 1개 GD Midea FT30-3D Motor Replacement, Motor: 12 단계, 이미지 2개 중 2개
      • At the base of the upper assembly there is a plug which conceals a screw.
      • The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
      댓글 쓰기
    2. GD Midea FT30-3D Motor Replacement: 13 단계, 이미지 1개 중 1개
      • Slide the motor out of the base of the upper assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alan Su
회원 가입일: 10/03/12
846 평판
안내서 6개를 작성함
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 회원
CPSU-REGAN-F12S24G28
4 회원들
안내서 15개를 작성함
4가이드 댓글
Alan Su (y contribuidores): Excelente aporte!!! Felicidades me ha sido muy útil. Gracias
Oliver K - 답글 공유
Hey. Could you tell me where to buy the spare motor from please?
Hywel Williams - 답글 공유
where can i buy the motor?
HAL SCHEDLER - 답글 공유
Where can I buy the motor???
anonymous 2683 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 18
지난 30일: 74
전체 시간: 8,396
