주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GE Washing Machine Agitator Replacement
비디오 가이드
이 가이드는 YouTube 동영상에서 필사한 것입니다.
필요한 것
      • Raise the lid to give full access to the agitator assembly.
      댓글 쓰기
      • Look for the small round hole located at the very bottom of the agitator skirt.
      • This hole is the only place where a tool can lock the agitator for removal.
      댓글 쓰기
      • Feel around the agitator base until you find the raised nipple on the washer plate.
      • Rotate the agitator until its hole lines up directly over the nipple.
      • Removal will not work unless these two features line up exactly.
      댓글 쓰기
      • Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
      • Push the screwdriver in deeply so it fully engages the mechanism.
      댓글 쓰기
      • Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
      • If working solo, brace the tub with your free hand while keeping the screwdriver seated.
      댓글 쓰기
      • Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
      • Lift the agitator straight up and out of the tub once it releases.
      댓글 쓰기
      • If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
      댓글 쓰기
      • Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
      • Lower the agitator onto the tabs until it sits flush on the plate.
      댓글 쓰기
      • Twist the agitator clockwise until it snaps and will not rotate freely.
      • Rock the agitator back and forth to confirm it is fully seated.
      댓글 쓰기
      • Press the fabric-softener dispenser cap back onto the agitator top.
      댓글 쓰기
결론
Repair didn't go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Ben Schlichter
회원 가입일: 01/21/25
7,128 평판
안내서 224개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 59
지난 30일: 257
전체 시간: 1,043
