주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GI Node Installation Guide
필요한 것
    1. GI Node Installation Guide, Select install location: 1 단계, 이미지 1개 중 1개
      • Locate a spot in the middle of the rain garden where the soil is bear/free from plants.
      • We need to install in the middle of the rain garden to ensure quality data.
      댓글 쓰기
    2. GI Node Installation Guide, Auger hole for node: 2 단계, 이미지 2개 중 1개 GI Node Installation Guide, Auger hole for node: 2 단계, 이미지 2개 중 2개
      • At the selected location, use a post hole digger to make a hole for the node.
      • Take your time so as to not disturb the soil too much.
      • Use a tape measure to make sure the hole is 3 feet deep.
      • The soil removed from the hole will fill roughly 2 buckets
      • Fill the first bucket with topsoil
      • When the soil begins to look like clay, switch to filling the second bucket
      댓글 쓰기
    3. GI Node Installation Guide, Install GI node: 3 단계, 이미지 2개 중 1개 GI Node Installation Guide, Install GI node: 3 단계, 이미지 2개 중 2개
      • Set the GI node into the 3 ft hole.
      • Do your best to make sure it is straight in the ground.
      • Pack the topsoil from the first bucket around the node to make sure it is secure in place. You shouldn't need to use any soil from the second bucket
      • If the surrounding plants are too tall, shading the solar panel, use the shears to trim the plants.
      댓글 쓰기
      • Fill out the deployment form on AirTable.
      • Once installed, confirm the GI node is reporting to the internet by going to its designated website.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Brooke Mason
회원 가입일: 05/29/19
2,958 평판
안내서 17개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 74개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 523
