주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GK61 Keyboard Keycap/Switch Replacement
필요한 것
    1. GK61 Keyboard Keycap/Switch Replacement, Keycap/Switches: 1 단계, 이미지 1개 중 1개
      • Unplug the keyboard.
      • When the keyboard lights are off, it indicates that the keyboard is turned off.
      댓글 쓰기
    2. GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 3개 중 1개 GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 3개 중 2개 GK61 Keyboard Keycap/Switch Replacement: 2 단계, 이미지 3개 중 3개
      • Use a keycap puller to remove the top and bottom of the keycaps from the keyboard.
      • When pulling the keycap, make sure to apply pressure until you hear a click sound from the keycap.
      • Remember when using a keycap puller, place it on a key in a vertical position.
      댓글 쓰기
    3. GK61 Keyboard Keycap/Switch Replacement: 3 단계, 이미지 1개 중 1개
      • After removing all the keycaps, put it in a bowl.
      • You can either use alcohol wipes or water to clean your keycaps.
      댓글 쓰기
    4. GK61 Keyboard Keycap/Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Dry the keycaps on a rag or paper towel.
      • Remember to let your keycaps dry for about 5-10 minutes after cleaning.
      댓글 쓰기
    5. GK61 Keyboard Keycap/Switch Replacement: 5 단계, 이미지 1개 중 1개
      • Using a hand held vacuum cleaner remove any excess dust, hair, and oils.
      • Tilting your keyboard will also help for a deeper clean
      • If you cannot locate a hand held vacuum cleaner, a compressed air duster will also work.
      댓글 쓰기
    6. GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 3개 중 1개 GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 3개 중 2개 GK61 Keyboard Keycap/Switch Replacement: 6 단계, 이미지 3개 중 3개
      • Using a Q-Tip with rubbing alcohol, gently clean and rub the crevices around the plate of the keyboard.
      • Make sure not to pour rubbing alcohol onto your keyboard. Doing so may cause severe damage to the keyboard.
      댓글 쓰기
    7. GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 3개 중 1개 GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 3개 중 2개 GK61 Keyboard Keycap/Switch Replacement: 7 단계, 이미지 3개 중 3개
      • Using a switch puller, pull the keyboard switch from the top and bottom of the switch.
      • Remember to always pull straight up to fully remove the switch.
      댓글 쓰기
    8. GK61 Keyboard Keycap/Switch Replacement: 8 단계, 이미지 2개 중 1개 GK61 Keyboard Keycap/Switch Replacement: 8 단계, 이미지 2개 중 2개
      • Grab a replacement switch to replace the broken switch.
      • Push the switch straight down into the socket of the switch.
      • To avoid any damages, make sure to always push straight down and not in any other direction.
      댓글 쓰기
    9. GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 3개 중 1개 GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 3개 중 2개 GK61 Keyboard Keycap/Switch Replacement: 9 단계, 이미지 3개 중 3개
      • After drying the keycaps, put the keycaps back into their sockets.
      • Align the keycap with the socket of the switch and push straight down with a bit of pressure.
      • When pushing straight down, you will hear a click sound that will indicate that the keycap has been placed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Alexander Truong
회원 가입일: 05/05/21
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 72
전체 시간: 2,422
