주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameSir Cyclone 2 LED Replacement
필요한 것
  1. GameSir Cyclone 2 LED Replacement, Face Plate: 1 단계, 이미지 3개 중 1개 GameSir Cyclone 2 LED Replacement, Face Plate: 1 단계, 이미지 3개 중 2개 GameSir Cyclone 2 LED Replacement, Face Plate: 1 단계, 이미지 3개 중 3개
    • Flip the controller around so the back part is facing you.
    • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
    • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
    댓글 쓰기
  2. GameSir Cyclone 2 LED Replacement: 2 단계, 이미지 1개 중 1개
    • The screws holding the face plate are of two different lengths:
    • The two longer screws belong to the two top screw sockets on the controller.
    • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
    댓글 쓰기
  3. GameSir Cyclone 2 LED Replacement: 3 단계, 이미지 2개 중 1개 GameSir Cyclone 2 LED Replacement: 3 단계, 이미지 2개 중 2개
    • Face the controller toward you.
    • Gently lift the face plate off the controller.
    • The d-pad and action buttons will become loose once the face plate is lifted.
    댓글 쓰기
  4. GameSir Cyclone 2 LED Replacement, Joystick Covers: 4 단계, 이미지 3개 중 1개 GameSir Cyclone 2 LED Replacement, Joystick Covers: 4 단계, 이미지 3개 중 2개 GameSir Cyclone 2 LED Replacement, Joystick Covers: 4 단계, 이미지 3개 중 3개
    • Pull both joystick covers straight up to remove them from the controller.
    댓글 쓰기
  5. GameSir Cyclone 2 LED Replacement, Left and Right Bumpers and Triggers: 5 단계, 이미지 1개 중 1개
    • Note the bumpers and triggers on the controller.
    댓글 쓰기
  6. GameSir Cyclone 2 LED Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
    • Remove the assembly that includes the power button and the top bumper buttons.
    댓글 쓰기
  7. GameSir Cyclone 2 LED Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the bumpers and triggers from the controller.
    댓글 쓰기
  8. GameSir Cyclone 2 LED Replacement, LED: 8 단계, 이미지 1개 중 1개
    • Locate the two black boxes towards the bottom of the controller.
    • Remove these two boxes by pulling them away from the controller. They should snap right off.
    댓글 쓰기
  9. GameSir Cyclone 2 LED Replacement: 9 단계, 이미지 1개 중 1개
    • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
    • Lift the upper ends of each LED diffuser and remove them.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ross Debortoli
회원 가입일: 10/17/25
325 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-6, Bowman Fall 2025 UMass Dartmouth, Team 2-6, Bowman Fall 2025 회원
UMASSD-BOWMAN-F25S2G6
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 60
전체 시간: 256
