주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameStop GS3 GameCube Controller Buttons Replacement
필요한 것
    1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
      • First, remove the 6 screws in the back panel and pull the back panel off.
      • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
      댓글 쓰기
    2. GameStop GS3 GameCube Controller Buttons Replacement: 2 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller Buttons Replacement: 2 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller Buttons Replacement: 2 단계, 이미지 3개 중 3개
      • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
      댓글 쓰기
    3. GameStop GS3 GameCube Controller Buttons Replacement: 3 단계, 이미지 3개 중 1개 GameStop GS3 GameCube Controller Buttons Replacement: 3 단계, 이미지 3개 중 2개 GameStop GS3 GameCube Controller Buttons Replacement: 3 단계, 이미지 3개 중 3개
      • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
      댓글 쓰기
    1. GameStop GS3 GameCube Controller Buttons Replacement, Buttons: 4 단계, 이미지 1개 중 1개
      • Hold the controller as shown in the picture so that you can remove the circuit board.
      • The locations of screws to be removed in future steps are shown in red.
      댓글 쓰기
    2. GameStop GS3 GameCube Controller Buttons Replacement: 5 단계, 이미지 2개 중 1개 GameStop GS3 GameCube Controller Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
      댓글 쓰기
    3. GameStop GS3 GameCube Controller Buttons Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
      댓글 쓰기
    4. GameStop GS3 GameCube Controller Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Now your controller front panel should look similar to this.
      • Remove the rubber backings on the buttons shown in red.
      • Snap them back in when you go to put the controller back together.
      댓글 쓰기
    5. GameStop GS3 GameCube Controller Buttons Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the buttons and you should have what you see here.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
11다른 기여자 명과 함께
Andrew Gonsalves
회원 가입일: 10/20/16
238 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G5
3 회원들
안내서 55개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 20
전체 시간: 1,417
