주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Approach S2 Battery Replacement
필요한 것
    1. Garmin Approach S2 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Garmin Approach S2 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
      댓글 쓰기
    2. Garmin Approach S2 Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the back cover carefully.
      • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
      댓글 쓰기
    1. Garmin Approach S2 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
      댓글 쓰기
    2. Garmin Approach S2 Battery Replacement: 4 단계, 이미지 2개 중 1개 Garmin Approach S2 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the green tape shrouding the battery connector.
      댓글 쓰기
    3. Garmin Approach S2 Battery Replacement: 5 단계, 이미지 2개 중 1개 Garmin Approach S2 Battery Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
      • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
      • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
      댓글 쓰기
    4. Garmin Approach S2 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
      • Remove the battery.
      댓글 쓰기
    5. Garmin Approach S2 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the green tape on the back of the battery, it can be reused later.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emily Kovacs
회원 가입일: 03/21/18
259 평판
안내서 1개를 작성함
IUPUI, Team S4-G1, Baechle Spring 2018 IUPUI, Team S4-G1, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S4G1
3 회원들
안내서 5개를 작성함
8가이드 댓글
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - 답글 공유
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - 답글 공유
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - 답글 공유
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - 답글 공유
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 53
지난 30일: 255
전체 시간: 46,441
