주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Approach S2 Motherboard Replacement
필요한 것
    1. Garmin Approach S2 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Garmin Approach S2 Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
      댓글 쓰기
    2. Garmin Approach S2 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the back cover carefully.
      • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
      댓글 쓰기
    1. Garmin Approach S2 Motherboard Replacement, Water Proof Gasket: 3 단계, 이미지 1개 중 1개
      • Remove the orange gasket.
      댓글 쓰기
    1. Garmin Approach S2 Motherboard Replacement, Screen: 4 단계, 이미지 1개 중 1개
      • Remove the screen and motherboard assembly from the case.
      댓글 쓰기
    2. Garmin Approach S2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
      댓글 쓰기
    3. Garmin Approach S2 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the screen from the golden metal clip.
      댓글 쓰기
    4. Garmin Approach S2 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
      댓글 쓰기
    5. Garmin Approach S2 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Garmin Approach S2 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the connector from the motherboard by pulling it free at the base.
      • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
      댓글 쓰기
    6. Garmin Approach S2 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the screen from the motherboard.
      • Notice our tape retaining the connector to the screen. This is so easy to rip!
      댓글 쓰기
    1. Garmin Approach S2 Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Remove the motherboard from the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Evan Miller
회원 가입일: 03/21/18
250 평판
안내서 2개를 작성함
IUPUI, Team S4-G1, Baechle Spring 2018 IUPUI, Team S4-G1, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S4G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 1,110
