주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Dezl 760LMT Screen Replacement
필요한 것
    1. Garmin Dezl 760LMT Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Garmin Dezl 760LMT Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
      댓글 쓰기
    2. Garmin Dezl 760LMT Screen Replacement: 2 단계, 이미지 3개 중 1개 Garmin Dezl 760LMT Screen Replacement: 2 단계, 이미지 3개 중 2개 Garmin Dezl 760LMT Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Using a metal spudger, pry the device apart.
      • To recombine them, line up the two halves of the device and press them together.
      댓글 쓰기
    3. Garmin Dezl 760LMT Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Turn the device over, laying it on its back with the screen facing upwards.
      • Lift the front panel away from the silver part of the back panel.
      • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
      댓글 쓰기
    1. Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: 4 단계, 이미지 2개 중 1개 Garmin Dezl 760LMT Screen Replacement, Screen Ribbon Cable: 4 단계, 이미지 2개 중 2개
      • Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
      댓글 쓰기
    2. Garmin Dezl 760LMT Screen Replacement: 5 단계, 이미지 2개 중 1개 Garmin Dezl 760LMT Screen Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Find and lift the small grey hinge at the end of the ribbon cable.
      • When handling the motherboard, make sure to wear an anti-static wrist strap.
      댓글 쓰기
    1. Garmin Dezl 760LMT Screen Replacement, Screen: 6 단계, 이미지 2개 중 1개 Garmin Dezl 760LMT Screen Replacement, Screen: 6 단계, 이미지 2개 중 2개
      • Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
      댓글 쓰기
    2. Garmin Dezl 760LMT Screen Replacement: 7 단계, 이미지 3개 중 1개 Garmin Dezl 760LMT Screen Replacement: 7 단계, 이미지 3개 중 2개 Garmin Dezl 760LMT Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Turn the screen over so that it is facing upwards.
      • Remove the front plate of the screen.
      • Lift the screen from its back casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Ryan Williams
회원 가입일: 09/28/16
763 평판
안내서 6개를 작성함
USF Tampa, Team 4-2, Passmore Fall 2016 USF Tampa, Team 4-2, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G2
4 회원들
안내서 42개를 작성함
2가이드 댓글
where can one by the replacement screen
tempestrogue - 답글 공유
Ebay sells these screens replacement - search online for “ZD070NA-03K “ or on google, even amazon sometimes has them. Its a hard to find screen so you will probably only get it from hong kong or china.
neilneves - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 33
전체 시간: 2,971
