주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin DriveSmart 55 EX Screen Replacement
필요한 것
  1. Garmin DriveSmart 55 EX Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    댓글 쓰기
  2. Garmin DriveSmart 55 EX Screen Replacement: 2 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Screen Replacement: 2 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    댓글 쓰기
  3. Garmin DriveSmart 55 EX Screen Replacement: 3 단계, 이미지 2개 중 1개 Garmin DriveSmart 55 EX Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    댓글 쓰기
  4. Garmin DriveSmart 55 EX Screen Replacement: 4 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Screen Replacement: 4 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
    • Be careful when removing the ribbon cable because it is thin and can tear easily.
    댓글 쓰기
  5. Garmin DriveSmart 55 EX Screen Replacement: 5 단계, 이미지 2개 중 1개 Garmin DriveSmart 55 EX Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a spudger or plastic opening tool into the gap between the screen and display frame.
    • Once a corner begins to lift, slowly slide the tool around the edges to release the clips securing them.
    • The screen is glass and if you use too much force it can shatter and crack the screen.
    • Separate the screen from the device.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jacob Behnke
회원 가입일: 03/11/26
707 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 26
전체 시간: 108
