주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Fenix 2 Motherboard Replacement
필요한 것
    1. Garmin Fenix 2 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Garmin Fenix 2 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Garmin Fenix 2 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
      댓글 쓰기
    2. Garmin Fenix 2 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Garmin Fenix 2 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
      댓글 쓰기
    3. Garmin Fenix 2 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Garmin Fenix 2 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
      • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
      댓글 쓰기
    1. Garmin Fenix 2 Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
      • Use a spudger to pry open the power ribbon from the main board.
      댓글 쓰기
    2. Garmin Fenix 2 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
      댓글 쓰기
    3. Garmin Fenix 2 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Use the spudger to pry the motherboard out of the housing.
      댓글 쓰기
    4. Garmin Fenix 2 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Once removed simply separate the digitizer from the main board.
      댓글 쓰기
    5. Garmin Fenix 2 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Garmin Fenix 2 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Lastly use your spudger tool to pry the data ribbon open from the motherboard. Once the ribbon is removed the board will be free and you can replace the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brandon Barger
회원 가입일: 02/13/16
1,219 평판
안내서 5개를 작성함
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G4
3 회원들
안내서 7개를 작성함
2가이드 댓글
Ottima, le prime guide che trovo per Garmin Fenix 2. Io metterei una foto con le specifiche della batteria. Saluti.
Ciro Filomeno - 답글 공유
Hi there, any idea where I can buy motherboard replacement for my Fenix 1?
hasmanizam - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 32
전체 시간: 5,103
