주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin GPS V Logic Board Replacement
필요한 것
    1. Garmin GPS V Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 1개 Garmin GPS V Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 2개 Garmin GPS V Logic Board Replacement, Logic Board: 1 단계, 이미지 3개 중 3개
      • Orient the GPS V backside up.
      • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
      댓글 쓰기
    2. Garmin GPS V Logic Board Replacement: 2 단계, 이미지 2개 중 1개 Garmin GPS V Logic Board Replacement: 2 단계, 이미지 2개 중 2개
      • With the spudger, gently pry the back plate off the unit starting at the corners.
      • Open the back plate about 35°, use the antenna side act like a hinge.
      • Do NOT remove the back plate all the way, there are cables connected to it.
      댓글 쓰기
    3. Garmin GPS V Logic Board Replacement: 3 단계, 이미지 2개 중 1개 Garmin GPS V Logic Board Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the white 8-pin connector on the logic board and disconnect it.
      • Open the device all the way, making sure to not disconnect the brown antenna wire.
      댓글 쓰기
    4. Garmin GPS V Logic Board Replacement: 4 단계, 이미지 2개 중 1개 Garmin GPS V Logic Board Replacement: 4 단계, 이미지 2개 중 2개
      • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
      • You may need to rotate the device to get better access to the screw.
      댓글 쓰기
    5. Garmin GPS V Logic Board Replacement: 5 단계, 이미지 3개 중 1개 Garmin GPS V Logic Board Replacement: 5 단계, 이미지 3개 중 2개 Garmin GPS V Logic Board Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the ribbon connector on the logic board.
      • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
      • With the spudger, gently work the ribbon cable out of the connector until it is free.
      댓글 쓰기
    6. Garmin GPS V Logic Board Replacement: 6 단계, 이미지 2개 중 1개 Garmin GPS V Logic Board Replacement: 6 단계, 이미지 2개 중 2개
      • With the spudger, gently pry out the logic board.
      • Be careful to not disconnect the brown antenna wire as you remove the logic board.
      댓글 쓰기
    7. Garmin GPS V Logic Board Replacement: 7 단계, 이미지 1개 중 1개
      • Locate the brown wire connection on the logic board.
      • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
      • It may take some time to heat the flux up before the wire can be pulled out.
      • Pull brown wire free of the logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Connor
회원 가입일: 01/23/12
194 평판
안내서 4개를 작성함
Cal Poly, Team 3-25, Amido Winter 2012 Cal Poly, Team 3-25, Amido Winter 2012 회원
CPSU-AMIDO-W12S3G25
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 6,062
