주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin GPSmap 60CSx Battery Terminal Replacement
필요한 것
    1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: 1 단계, 이미지 1개 중 1개
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Battery Terminal Replacement: 2 단계, 이미지 1개 중 1개
      • Lift battery release up to remove battery cover.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Battery Terminal Replacement: 3 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Battery Terminal Replacement: 3 단계, 이미지 2개 중 2개
      • Pull AA batteries out.
      댓글 쓰기
    1. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: 4 단계, 이미지 1개 중 1개
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Battery Terminal Replacement: 5 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Battery Terminal Replacement: 5 단계, 이미지 2개 중 2개
      • Place spudger behind the lower right battery terminal.
      • Push spudger behind the battery terminal to pop it out of place.
      • Now do the same on the bottom left side.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Battery Terminal Replacement: 6 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Battery Terminal Replacement: 6 단계, 이미지 2개 중 2개
      • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
      댓글 쓰기
    4. Garmin GPSmap 60CSx Battery Terminal Replacement: 7 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Battery Terminal Replacement: 7 단계, 이미지 2개 중 2개
      • Flip the back panel over to expose the backs of the top battery terminals.
      • Use a metal spudger to remove the glue that covers them.
      댓글 쓰기
    5. Garmin GPSmap 60CSx Battery Terminal Replacement: 8 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Battery Terminal Replacement: 8 단계, 이미지 2개 중 2개
      • Flip the back panel back over to view the battery compartment.
      • Place the spudger behind one of the top remaining battery terminals.
      • Push the spudger down and pop the battery terminal out of place.
      • Repeat with the remaining battery terminal.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Thomas Humphrey
회원 가입일: 04/05/18
546 평판
안내서 4개를 작성함
10가이드 댓글
What did you use to replace the contacts?
Austin Chopra - 답글 공유
Where can I buy replacement terminals?
Mitch - 답글 공유
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons - 답글 공유
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - 답글 공유
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 116
전체 시간: 12,193
