주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin GPSmap 60CSx Keypad Buttons Replacement
필요한 것
    1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: 1 단계, 이미지 1개 중 1개
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Keypad Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Lift battery release up to remove battery cover.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Keypad Buttons Replacement: 3 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Keypad Buttons Replacement: 3 단계, 이미지 2개 중 2개
      • Pull AA batteries out.
      댓글 쓰기
    1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: 4 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: 4 단계, 이미지 2개 중 2개
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
      • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
      • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Keypad Buttons Replacement: 5 단계, 이미지 1개 중 1개
      • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
      • The previous step will need to be done to the other three corners.
      • It is best to do the two bottom corners first.
      • Pull the black PCB board out of the GPSMap 60 CSx.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Keypad Buttons Replacement: 6 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Keypad Buttons Replacement: 6 단계, 이미지 2개 중 2개
      • Carefully use a spudger to lift the PCB a few centimeters.
      • Pull the PCB out towards the bottom of the GPSMap 60CSx.
      • This will pull out all the main components including the antenna and the screen.
      댓글 쓰기
    4. Garmin GPSmap 60CSx Keypad Buttons Replacement: 7 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Keypad Buttons Replacement: 7 단계, 이미지 2개 중 2개
      • Take the front panel and apply light force to the buttons.
      • The buttons are part of one unit and should all pop out at once.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Thomas Humphrey
회원 가입일: 04/05/18
546 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 45
전체 시간: 3,356
