주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin GPSmap 60CSx Screen Replacement
필요한 것
    1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: 1 단계, 이미지 1개 중 1개
      • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Lift battery release up to remove battery cover.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Screen Replacement: 3 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Screen Replacement: 3 단계, 이미지 2개 중 2개
      • Pull AA batteries out.
      댓글 쓰기
    1. Garmin GPSmap 60CSx Screen Replacement, Screen: 4 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Screen Replacement, Screen: 4 단계, 이미지 2개 중 2개
      • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
      • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
      • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
      댓글 쓰기
    2. Garmin GPSmap 60CSx Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Take the spudger and place it in the bottom right corner of the black PCB cover.
      • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
      • It is best to do remove the bottom corners first.
      • Pull the PCB cover out of the GPSMap 60CSx.
      댓글 쓰기
    3. Garmin GPSmap 60CSx Screen Replacement: 6 단계, 이미지 2개 중 1개 Garmin GPSmap 60CSx Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Carefully use the spudger to lift the PCB a few centimeters.
      • Pull the PCB towards the bottom of the GPSMap 60CSx.
      • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
      댓글 쓰기
    4. Garmin GPSmap 60CSx Screen Replacement: 7 단계, 이미지 3개 중 1개 Garmin GPSmap 60CSx Screen Replacement: 7 단계, 이미지 3개 중 2개 Garmin GPSmap 60CSx Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Apply light pressure to the four white tabs that are holding the screen in place.
      • The screen will now come off the PCB.
      댓글 쓰기
    5. Garmin GPSmap 60CSx Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Turn the PCB over so the screen connector is facing you.
      • Move the screen out of the way for access to the screen connector.
      댓글 쓰기
    6. Garmin GPSmap 60CSx Screen Replacement: 9 단계, 이미지 3개 중 1개 Garmin GPSmap 60CSx Screen Replacement: 9 단계, 이미지 3개 중 2개 Garmin GPSmap 60CSx Screen Replacement: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use tweezers to pull the two white pins on the connector forward.
      댓글 쓰기
    7. Garmin GPSmap 60CSx Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the screen ribbon connector and screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Thomas Humphrey
회원 가입일: 04/05/18
546 평판
안내서 4개를 작성함
2가이드 댓글
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - 답글 공유
Thank you for these step by step detailed instructions.
jlciscorp - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 51
전체 시간: 5,751
