주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin StreetPilot c320 LCD Screen Replacement
필요한 것
    1. Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: 1 단계, 이미지 2개 중 1개 Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: 1 단계, 이미지 2개 중 2개
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      댓글 쓰기
    2. Garmin StreetPilot c320 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Garmin StreetPilot c320 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      댓글 쓰기
    3. Garmin StreetPilot c320 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      댓글 쓰기
    1. Garmin StreetPilot c320 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
      댓글 쓰기
    2. Garmin StreetPilot c320 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Slightly lift the motherboard upwards to reveal the LCD assembly.
      • Do not remove the motherboard yet, as it is stil attached to the LCD.
      댓글 쓰기
    3. Garmin StreetPilot c320 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
      • Disconnect the right connector using the edge of a plastic opening tool.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Arturo Barajas
회원 가입일: 01/18/12
11 평판
안내서 3개를 작성함
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 회원
CPSU-MANESS-W12S11G19
4 회원들
안내서 12개를 작성함
1가이드 댓글
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
Ricky Graham - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 23
전체 시간: 1,844
