주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway LT4004u Screen Replacement
필요한 것
  1. Gateway LT4004u Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Open the laptop so that the screen and keyboard are facing you.
    • Remove the two screw covers at the bottom right and left corners of the screen using tweezers.
    댓글 쓰기
  2. Gateway LT4004u Screen Replacement: 2 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement: 2 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the two 5.0mm screws underneath the screen covers on the left and right side and remove them from the laptop. For this step and the following steps, use a Phillips #0 head screwdriver.
    댓글 쓰기
  3. Gateway LT4004u Screen Replacement: 3 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement: 3 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Once the two screws are removed, pry the screen casing away from the screen. You can use your fingernails or a tool such as tweezers to separate the screen casing from the backing.
    • Be prepared to hear cracking noises. These are expected.
    • Unhook the screen casing at the bottom of the screen from the central hinges on the left and right side connecting the screen casing to the keyboard.
    • Remove the screen casing.
    댓글 쓰기
  4. Gateway LT4004u Screen Replacement: 4 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement: 4 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Once the screen casing is removed, unscrew the 8 screws surrounding the screen and remove them from the laptop. All 8 screws should measure 4.0mm long.
    • There is a single screw in each red indicator and two screws in each orange indicator, totaling to the eight screws.
    댓글 쓰기
  5. Gateway LT4004u Screen Replacement: 5 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement: 5 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Unplug the webcam connection from the top of the laptop screen backing.
    댓글 쓰기
  6. Gateway LT4004u Screen Replacement: 6 단계, 이미지 3개 중 1개 Gateway LT4004u Screen Replacement: 6 단계, 이미지 3개 중 2개 Gateway LT4004u Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the screen over so that it is lying on top of the keyboard.
    • Looking at the underside of the screen, remove the yellow tape and carefully remove the wires attaching the screen to the laptop.
    댓글 쓰기
  7. Gateway LT4004u Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screen from the rest of the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Carlisle Hiott
회원 가입일: 03/21/16
821 평판
안내서 7개를 작성함
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 회원
CLEM-BENSON-S16S6G5
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 42
전체 시간: 961
