주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway Lt4004u Keyboard Replacement
필요한 것
  1. Gateway Lt4004u Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Gateway Lt4004u Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Gateway Lt4004u Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the laptop face down in front of you.
    • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
    • Pinch the switches and slide toward the edges of the computer to unlock.
    댓글 쓰기
  2. Gateway Lt4004u Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Gateway Lt4004u Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
    • Remove the battery from the laptop.
    댓글 쓰기
  3. Gateway Lt4004u Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Gateway Lt4004u Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Gateway Lt4004u Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Open the laptop so that the screen and keyboard are facing you.
    • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
    댓글 쓰기
  4. Gateway Lt4004u Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Gateway Lt4004u Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Gateway Lt4004u Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Use an opening pick to push each tab away from you.
    • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
    • A clicking sound is normal and no cause for alarm.
    댓글 쓰기
  5. Gateway Lt4004u Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Gateway Lt4004u Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Gateway Lt4004u Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
    • Carefully pry the keyboard from the main frame, starting at the top section.
    • Look at the intel sticker in this step and the next to orient your computer with the pictures.
    댓글 쓰기
  6. Gateway Lt4004u Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Gateway Lt4004u Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
    • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
    • The popping noise will not hurt the computer.
    • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Carlisle Hiott
회원 가입일: 03/21/16
821 평판
안내서 7개를 작성함
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 회원
CLEM-BENSON-S16S6G5
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 901
