주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway MA7 Fan Replacement
필요한 것
  1. Gateway MA7 Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Before starting this replacement, make sure the device is powered off and the battery is removed.
    • This particular device is missing the battery.
    • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
    댓글 쓰기
  2. Gateway MA7 Fan Replacement: 2 단계, 이미지 3개 중 1개 Gateway MA7 Fan Replacement: 2 단계, 이미지 3개 중 2개 Gateway MA7 Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
    댓글 쓰기
  3. Gateway MA7 Fan Replacement: 3 단계, 이미지 3개 중 1개 Gateway MA7 Fan Replacement: 3 단계, 이미지 3개 중 2개 Gateway MA7 Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
    댓글 쓰기
  4. Gateway MA7 Fan Replacement: 4 단계, 이미지 2개 중 1개 Gateway MA7 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
    • The four screws on the silver metal bands of the fan will not come off of the actual component.
    댓글 쓰기
  5. Gateway MA7 Fan Replacement: 5 단계, 이미지 3개 중 1개 Gateway MA7 Fan Replacement: 5 단계, 이미지 3개 중 2개 Gateway MA7 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
    • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
    • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
    댓글 쓰기
  6. Gateway MA7 Fan Replacement: 6 단계, 이미지 3개 중 1개 Gateway MA7 Fan Replacement: 6 단계, 이미지 3개 중 2개 Gateway MA7 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
    • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
    댓글 쓰기
  7. Gateway MA7 Fan Replacement: 7 단계, 이미지 3개 중 1개 Gateway MA7 Fan Replacement: 7 단계, 이미지 3개 중 2개 Gateway MA7 Fan Replacement: 7 단계, 이미지 3개 중 3개
    • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
    • When you replace the fan, be sure to reapply thermal paste here.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Cameron Sheedy
회원 가입일: 03/05/18
145 평판
안내서 1개를 작성함
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G2
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 32
전체 시간: 879
