주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway MS2370 Fan Replacement
필요한 것
  1. Gateway MS2370 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
    댓글 쓰기
  2. Gateway MS2370 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
    댓글 쓰기
  3. Gateway MS2370 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the battery from the laptop to remove it.
    댓글 쓰기
  4. Gateway MS2370 Fan Replacement, RAM: 4 단계, 이미지 1개 중 1개
    • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
    • Unplug everything from the USB and SD ports.
    댓글 쓰기
  5. Gateway MS2370 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the cover panel.
    • This exposes more screws that must be removed.
    댓글 쓰기
  6. Gateway MS2370 Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the two exposed cables from the motherboard.
    댓글 쓰기
  7. Gateway MS2370 Fan Replacement: 7 단계, 이미지 2개 중 1개 Gateway MS2370 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
    • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
    댓글 쓰기
  8. Gateway MS2370 Fan Replacement: 8 단계, 이미지 2개 중 1개 Gateway MS2370 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Pry the laptop case apart.
    • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
    댓글 쓰기
  9. Gateway MS2370 Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
    • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
    • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
    댓글 쓰기
  10. Gateway MS2370 Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the top half of the case.
    댓글 쓰기
  11. Gateway MS2370 Fan Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew all 5 10mm inch Phillips 01 screws.
    • One more off screen
    댓글 쓰기
  12. Gateway MS2370 Fan Replacement: 12 단계, 이미지 3개 중 1개 Gateway MS2370 Fan Replacement: 12 단계, 이미지 3개 중 2개 Gateway MS2370 Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
    댓글 쓰기
  13. Gateway MS2370 Fan Replacement: 13 단계, 이미지 1개 중 1개
    • Flip the motherboard over.
    댓글 쓰기
  14. Gateway MS2370 Fan Replacement: 14 단계, 이미지 3개 중 1개 Gateway MS2370 Fan Replacement: 14 단계, 이미지 3개 중 2개 Gateway MS2370 Fan Replacement: 14 단계, 이미지 3개 중 3개
    • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
    • The last step of this replacement guide is not required to complete the fan replacement guide.
    댓글 쓰기
  15. Gateway MS2370 Fan Replacement, Fan: 15 단계, 이미지 1개 중 1개
    • Unscrew the three 3mm inch Phillips 01 screws.
    • These screws will not be removed entirely. Just loosen them enough to free the fan from the motherboard.
    댓글 쓰기
  16. Gateway MS2370 Fan Replacement: 16 단계, 이미지 1개 중 1개
    • Unplug the fan cable from the motherboard.
    댓글 쓰기
  17. Gateway MS2370 Fan Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the Fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Erickson Rodrigues
회원 가입일: 10/17/17
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 28
전체 시간: 924
