주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway NE52203u Optical Drive Replacement
필요한 것
  1. Gateway NE52203u Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the device over onto its backside in order to access the battery.
    댓글 쓰기
  2. Gateway NE52203u Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 Gateway NE52203u Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
    댓글 쓰기
  3. Gateway NE52203u Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
    댓글 쓰기
  4. Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: 4 단계, 이미지 2개 중 1개 Gateway NE52203u Optical Drive Replacement, Touchpad Assembly: 4 단계, 이미지 2개 중 2개
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
    댓글 쓰기
  5. Gateway NE52203u Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
    댓글 쓰기
  6. Gateway NE52203u Optical Drive Replacement: 6 단계, 이미지 2개 중 1개 Gateway NE52203u Optical Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
    댓글 쓰기
  7. Gateway NE52203u Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
    댓글 쓰기
  8. Gateway NE52203u Optical Drive Replacement: 8 단계, 이미지 3개 중 1개 Gateway NE52203u Optical Drive Replacement: 8 단계, 이미지 3개 중 2개 Gateway NE52203u Optical Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
    댓글 쓰기
  9. Gateway NE52203u Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 1개 Gateway NE52203u Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 2개 Gateway NE52203u Optical Drive Replacement, Optical Drive: 9 단계, 이미지 3개 중 3개
    • Grasp the plastic placeholder firmly and slide it out of the computer.
    • When inserting replacement optical drive, use the port at the back left of the open space.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Stephen Spees
회원 가입일: 03/20/15
542 평판
안내서 4개를 작성함
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015 회원
BU-GRIGSBY-S15S2G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 725
