주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway NV52 Keyboard Replacement
필요한 것
  1. Gateway NV52 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    댓글 쓰기
  2. Gateway NV52 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    댓글 쓰기
  3. Gateway NV52 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the horizontal latch to the right to pop open the battery pack.
    댓글 쓰기
  4. Gateway NV52 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    댓글 쓰기
  5. Gateway NV52 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    댓글 쓰기
  6. Gateway NV52 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    댓글 쓰기
  7. Gateway NV52 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    댓글 쓰기
  8. Gateway NV52 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tim En
회원 가입일: 01/26/13
557 평판
안내서 4개를 작성함
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 회원
CPSU-REGAN-S14S7G24
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 46
전체 시간: 2,668
