주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway SA1 Screen Replacement
필요한 것
  1. Gateway SA1 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Move the latch to the right of the battery to unlock.
    댓글 쓰기
  2. Gateway SA1 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    댓글 쓰기
  3. Gateway SA1 Screen Replacement, Screen: 3 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement, Screen: 3 단계, 이미지 2개 중 2개
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
    댓글 쓰기
  4. Gateway SA1 Screen Replacement: 4 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the six screw covers on the front bezel with the sharp point of the spudger.
    • The bottom two are more difficult to remove.
    댓글 쓰기
  5. Gateway SA1 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the six 5.9 mm Philips screws securing the screen bezel.
    댓글 쓰기
  6. Gateway SA1 Screen Replacement: 6 단계, 이미지 3개 중 1개 Gateway SA1 Screen Replacement: 6 단계, 이미지 3개 중 2개 Gateway SA1 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the front bezel by prying it off with the wedged end of the spudger.
    • Verify that your spudger does not touch the LCD.
    • The screen inverter is now exposed below the LCD.
    댓글 쓰기
  7. Gateway SA1 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the single 3.8mm Phillips screw mounting the screen inverter to the computer.
    댓글 쓰기
  8. Gateway SA1 Screen Replacement: 8 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use your finger, or the spudger, to pry the inverter board out.
    • This exposes the wires behind it.
    댓글 쓰기
  9. Gateway SA1 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Unplug the LCD back light cables from the right side of the screen inverter.
    댓글 쓰기
  10. Gateway SA1 Screen Replacement: 10 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the six screws that mount the screen to the hinge mounts.
    • Two 2.5 mm Phillips screws.
    • Four 3.8 mm Phillips screws.
    댓글 쓰기
  11. Gateway SA1 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Unplug the cable from the webcam board.
    • Be gentle, do not use excessive force or you may break the connection.
    댓글 쓰기
  12. Gateway SA1 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Separate the screen from the display cover.
    • Do not touch the back of the screen.
    댓글 쓰기
  13. Gateway SA1 Screen Replacement: 13 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the three tape strips that hold down the cables.
    • Be careful not to tear any of the tape. The piece holding down the webcam wires is especially delicate.
    댓글 쓰기
  14. Gateway SA1 Screen Replacement: 14 단계, 이미지 2개 중 1개 Gateway SA1 Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Unplug the display data cable from the screen connector.
    • This connection is very fragile; do not use excessive force.
    • The screen should now be free from all wire connections.
    댓글 쓰기
  15. Gateway SA1 Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the four 2.8 mm Phillips screws that secure the screen to the mounting bracket using a screwdriver.
    • There will be two screws on either side of the mounting bracket.
    댓글 쓰기
  16. Gateway SA1 Screen Replacement: 16 단계, 이미지 1개 중 1개
    • You can now remove and replace the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Diego Carteno
회원 가입일: 04/15/10
273 평판
안내서 7개를 작성함
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 회원
CPSU-REGAN-S10S24G20
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 38
전체 시간: 19,447
