주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway W350I Display Replacement
필요한 것
  1. Gateway W350I Display Replacement, Battery Access: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down and position it as shown in the image.
    댓글 쓰기
  2. Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 1개 Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 2개 Gateway W350I Display Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 3개
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    댓글 쓰기
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 3 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 3 단계, 이미지 2개 중 2개
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
    댓글 쓰기
  4. Gateway W350I Display Replacement, Separate Plastic Casing: 4 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Separate Plastic Casing: 4 단계, 이미지 2개 중 2개
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
    댓글 쓰기
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 5 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 5 단계, 이미지 2개 중 2개
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
    댓글 쓰기
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: 6 단계, 이미지 1개 중 1개
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
    댓글 쓰기
  7. Gateway W350I Display Replacement, Remove Video Cable: 7 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement, Remove Video Cable: 7 단계, 이미지 2개 중 2개
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
    댓글 쓰기
  8. Gateway W350I Display Replacement: 8 단계, 이미지 2개 중 1개 Gateway W350I Display Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the camera connector from the circuit board to completely free the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Samuel Newton
회원 가입일: 09/22/14
308 평판
안내서 1개를 작성함
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 회원
USFT-BROWN-F14S4G1
3 회원들
안내서 10개를 작성함
1가이드 댓글
It was very easy to follow.
Very friendly guide.
stewilli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 31
전체 시간: 1,738
