주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway W350I Keyboard Replacement
필요한 것
  1. Gateway W350I Keyboard Replacement, Battery Access: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down and position it as shown in the image.
    댓글 쓰기
  2. Gateway W350I Keyboard Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 1개 Gateway W350I Keyboard Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 2개 Gateway W350I Keyboard Replacement, Unlocking the Battery: 2 단계, 이미지 3개 중 3개
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    댓글 쓰기
  3. Gateway W350I Keyboard Replacement, Unscrewing the Speaker Cover Panel: 3 단계, 이미지 1개 중 1개
    • Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
    댓글 쓰기
  4. Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: 4 단계, 이미지 2개 중 1개 Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the 4mm Phillips #0 screw that secures the keyboard.
    댓글 쓰기
  5. Gateway W350I Keyboard Replacement, Repositioning the Device: 5 단계, 이미지 1개 중 1개
    • Reposition the laptop so that it is upright with the display open.
    댓글 쓰기
  6. Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: 6 단계, 이미지 3개 중 1개 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: 6 단계, 이미지 3개 중 2개 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: 6 단계, 이미지 3개 중 3개
    • Carefully pry up on the right and left sides of the speaker cover panel.
    • The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
    댓글 쓰기
  7. Gateway W350I Keyboard Replacement, Removing the Keyboard: 7 단계, 이미지 2개 중 1개 Gateway W350I Keyboard Replacement, Removing the Keyboard: 7 단계, 이미지 2개 중 2개
    • Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
    댓글 쓰기
  8. Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: 8 단계, 이미지 2개 중 1개 Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: 8 단계, 이미지 2개 중 2개
    • Pull on the cord connecting the keyboard to the computer until it slides out.
    • Be careful while removing the cord as it is very delicate.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Spencer
회원 가입일: 09/22/14
278 평판
안내서 2개를 작성함
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 회원
USFT-BROWN-F14S4G1
3 회원들
안내서 10개를 작성함
1가이드 댓글
Great guide guys!
stewilli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 46
전체 시간: 1,878
