주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Geek Chef 4 Slice Toaster Disassembly
필요한 것
    1. Geek Chef 4 Slice Toaster Disassembly, Geek Chef 4 Slice Toaster: 1 단계, 이미지 2개 중 1개 Geek Chef 4 Slice Toaster Disassembly, Geek Chef 4 Slice Toaster: 1 단계, 이미지 2개 중 2개
      • Pull off the handles from each toasting arm.
      • These handles will require a decent amount of force to pull off of the toaster.
      댓글 쓰기
    2. Geek Chef 4 Slice Toaster Disassembly: 2 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 2 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 2 단계, 이미지 3개 중 3개
      • Turn the toaster upside down.
      • Remove the seven 10.5mm screws from the bottom panel using a Phillips #00 screwdriver.
      댓글 쓰기
    3. Geek Chef 4 Slice Toaster Disassembly: 3 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 3 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 3 단계, 이미지 3개 중 3개
      • Slide out the crumb pans located in the bottom of the toaster.
      • Remove the four 10 mm screws using a Triangle #2 screwdriver.
      댓글 쓰기
    4. Geek Chef 4 Slice Toaster Disassembly: 4 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 4 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 4 단계, 이미지 3개 중 3개
      • Flip the toaster right side up.
      • Slowly remove the encasing of the toaster.
      • There will be two 4-pin connectors that connect the top encasing and the body of the toaster; be careful to not rip this connector when lifting the encasing.
      • Gently remove the 4-pin connector from the circuit board attached to the encasing of the toaster.
      댓글 쓰기
    5. Geek Chef 4 Slice Toaster Disassembly: 5 단계, 이미지 1개 중 1개
      • Gently set the encasing aside.
      • You will not need the encasing for the rest of the guide, so place it aside away from the rest of the body.
      댓글 쓰기
    6. Geek Chef 4 Slice Toaster Disassembly: 6 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 6 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 6 단계, 이미지 3개 중 3개
      • Remove the four 10 mm screws holding down one of the toasting modules using a Phillips #00 screwdriver.
      댓글 쓰기
    7. Geek Chef 4 Slice Toaster Disassembly: 7 단계, 이미지 1개 중 1개
      • Pry out the circuit board attached to the toasting body from its plastic holding pieces.
      • Again, there will be a decent amount of force required. Ensure that you pry one side at a time, wiggling the board out instead of ripping it out. You will not break anything even with a decent amount of force.
      댓글 쓰기
    8. Geek Chef 4 Slice Toaster Disassembly: 8 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 8 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 8 단계, 이미지 3개 중 3개
      • Unbend the four metal tabs that connect the cap of the toasting module to the rest of the module using pliers.
      • Unbend the tabs so that they slip through the holes holding the cap in place.
      • Be extremely careful with all of the metal tabs, as they are fragile, and bending one incorrectly could result in an inability in reassembling the toaster.
      • From now on, most of the parts removed will be secured using tabs, so make sure your pliers aren't too large; otherwise you won't be able to fit them into all of the needed disassembly locations. We used needle nose pliers.
      댓글 쓰기
    9. Geek Chef 4 Slice Toaster Disassembly: 9 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 9 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 9 단계, 이미지 3개 중 3개
      • Remove the cap of the toasting module.
      댓글 쓰기
    10. Geek Chef 4 Slice Toaster Disassembly: 10 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 10 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 10 단계, 이미지 3개 중 3개
      • Unbend the small metal tab securing the larger, thin, rectangular metal sheet bent above it.
      • Bend the larger sheet so it is fully vertical.
      댓글 쓰기
    11. Geek Chef 4 Slice Toaster Disassembly: 11 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 11 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 11 단계, 이미지 3개 중 3개
      • Remove the metal rod poking out of the top.
      • While pulling out the rod, two springs will pop out: a shorter and longer one. Make sure to keep track of these; gently pulling out the rod will help with this.
      댓글 쓰기
    12. Geek Chef 4 Slice Toaster Disassembly: 12 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 12 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 12 단계, 이미지 3개 중 3개
      • Carefully bend the two metal tabs in the front and back of the toaster that connect the middle securing metal part to the rest of the toaster.
      • Unbend the tabs so that they fit through the holes they're secured to.
      • Remove this securing part.
      • Beyond this step, we will only be disassembling one slice section of the toaster, but all of the steps are applicable for all slice sections.
      댓글 쓰기
    13. Geek Chef 4 Slice Toaster Disassembly: 13 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 13 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 13 단계, 이미지 3개 중 3개
      • Un-loop the loose, hanging part of the lever mechanism from the black spring.
      • Un-loop the black spring from where the rod (that you just took out of the slot) used to run through.
      • Set the spring aside.
      댓글 쓰기
    14. Geek Chef 4 Slice Toaster Disassembly: 14 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 14 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 14 단계, 이미지 3개 중 3개
      • Carefully bend the metal tabs at the rear of the bottom toast holders so they can fit through the slot at the back.
      • Push these two arms up so the angled arms (jutting out from the middle of each toast holder) fit through the top y-shaped cutout on the toasting body.
      • Slide out these holders by pulling the module and wiggling it by the black plastic that holds the two pieces together.
      • This last step may require a bit of force; nothing will break as long as you pull in a controlled manner.
      댓글 쓰기
    15. Geek Chef 4 Slice Toaster Disassembly: 15 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 15 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 15 단계, 이미지 3개 중 3개
      • Bend the tabs on the outside of the toaster's side so that they can fit through the holes they are currently secured to.
      • Do not remove the side of the toasting body yet; this will damage the interior of the toaster.
      댓글 쓰기
    16. Geek Chef 4 Slice Toaster Disassembly: 16 단계, 이미지 2개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 16 단계, 이미지 2개 중 2개
      • Unbend the three metal tabs on the top of the side body so they are straight between the tabs of the interior of the toaster.
      • Be very careful when unbending these metal tabs; the interior of the toaster is very fragile, and if the interior tabs of the toaster are damaged it can make the reassembly extremely difficult.
      댓글 쓰기
    17. Geek Chef 4 Slice Toaster Disassembly: 17 단계, 이미지 1개 중 1개
      • Remove the side panel slowly, watching to see if it gets caught on any interior pieces of the toaster. If so, bend these pieces so they don't rip any part of the interior foam region.
      댓글 쓰기
    18. Geek Chef 4 Slice Toaster Disassembly: 18 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 18 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 18 단계, 이미지 3개 중 3개
      • Flip the toasting body upside down.
      • Unbend all of the metal tabs on the middle bottom cover so that they fit through the holes securing the piece.
      • Gently remove the piece.
      • Keep in mind that it also is in contact with the middle-most foam pieces of the toaster when removing, as although unlikely, you do not want to damage this interior.
      댓글 쓰기
    19. Geek Chef 4 Slice Toaster Disassembly: 19 단계, 이미지 3개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 19 단계, 이미지 3개 중 2개 Geek Chef 4 Slice Toaster Disassembly: 19 단계, 이미지 3개 중 3개
      • Flip the toasting body right side up.
      • Gently remove the black spring from both small metal arms by threading the looped part surrounding the metal arm off of the small metal arm, circled in red.
      댓글 쓰기
    20. Geek Chef 4 Slice Toaster Disassembly: 20 단계, 이미지 2개 중 1개 Geek Chef 4 Slice Toaster Disassembly: 20 단계, 이미지 2개 중 2개
      • Gently remove both toast holding metal pieces.
      • This will require slightly bending the front and back of the toasting body outward to allow for the small rods, circled in red, to be released.
      • The small arms must also be maneuvered out of the holes provided to remove the toast holding metal pieces.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
DaveyB
회원 가입일: 09/11/25
351 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 37
전체 시간: 291
