주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Generic DualShock 2 Cable Pinout
필요한 것
  1. Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: 1 단계, 이미지 2개 중 1개 Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: 1 단계, 이미지 2개 중 2개
    • First, check that the connection port of your controller (whether wireless or not) has all the pins.
    • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
    댓글 쓰기
  2. Generic DualShock 2 Cable Pinout: 2 단계, 이미지 2개 중 1개 Generic DualShock 2 Cable Pinout: 2 단계, 이미지 2개 중 2개
    • Flip Over Controller and remove all 6 screws from the bottom of the controller.
    댓글 쓰기
  3. Generic DualShock 2 Cable Pinout: 3 단계, 이미지 2개 중 1개 Generic DualShock 2 Cable Pinout: 3 단계, 이미지 2개 중 2개
    • Once the screws are removed, carefully pry the controller open with your hands.
    • Remove the screw holding the circuit board in place.
    댓글 쓰기
  4. Generic DualShock 2 Cable Pinout: 4 단계, 이미지 1개 중 1개
    • Carefully remove the circuit board from the front cover of the controller.
    댓글 쓰기
  5. Generic DualShock 2 Cable Pinout: 5 단계, 이미지 1개 중 1개
    • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
    댓글 쓰기
  6. Generic DualShock 2 Cable Pinout: 6 단계, 이미지 1개 중 1개
    • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
    댓글 쓰기
  7. Generic DualShock 2 Cable Pinout: 7 단계, 이미지 1개 중 1개
    • Check the connection of the flexible trigger board to the main circuit board of your controller.
    댓글 쓰기
  8. Generic DualShock 2 Cable Pinout: 8 단계, 이미지 1개 중 1개
    • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
    댓글 쓰기
  9. Generic DualShock 2 Cable Pinout: 9 단계, 이미지 1개 중 1개
    • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
    댓글 쓰기
  10. Generic DualShock 2 Cable Pinout, Cable Color And Order: 10 단계, 이미지 2개 중 1개 Generic DualShock 2 Cable Pinout, Cable Color And Order: 10 단계, 이미지 2개 중 2개
    • Here it is how it should be connected.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bruno Melo
회원 가입일: 02/07/19
178 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 70
지난 30일: 298
전체 시간: 11,126
