주요 콘텐츠로 건너뛰기
Gentle method - HP Photosmart Plus B210a Printhead Cleaning
필요한 것
추천 문서
  1. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Ink tank removal: 1 단계, 이미지 1/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Ink tank removal: 1 단계, 이미지 2/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Ink tank removal: 1 단계, 이미지 3/3
    • Remove the ink cartridges from the printer. Install the shipping caps or put the ink cartridges in a plastic bag.
  2. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Remove the printhead (See calibration warning): 2 단계, 이미지 1/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Remove the printhead (See calibration warning): 2 단계, 이미지 2/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Remove the printhead (See calibration warning): 2 단계, 이미지 3/3
    • If the printhead is being removed for cleaning and is plugged in, the calibration data may be erased. Verify the printer is unplugged BEFORE REMOVING the printhead!
    • When the printer is unplugged, lift the lever up and remove the printhead.
    • Remove the printhead as shown. IMPORTANT: Leave the scanner lid open, or put a note near the printer.
  3. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Clean the printer contacts: 3 단계, 이미지 1/2 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Clean the printer contacts: 3 단계, 이미지 2/2
    • Failure to clean this area may result in an Ink System Failure warning. If you are cleaning the printhead, this error will destroy your existing calibration!
    • Using an alcohol wipe, clean the printhead interface on the printer before installing the replacement part to avoid any errors like Ink System Failure.
  4. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Gather your supplies: 4 단계, 이미지 1/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Gather your supplies: 4 단계, 이미지 2/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Gather your supplies: 4 단계, 이미지 3/3
    • In addition to the parts listing, these items are highly recommended:
    • Ink protection: Plastic bag or ink caps
    • Only needed in specific cases: Replacement ink for preparation process after cleaning (3rd party ink works, but will nag you).
    • This is only needed if your current ink set is risky to use in the event of a lost calibration (i.e. refilled with a used HP chip); RECOMMENDED if you use non-XL carts.
    • Optional (Stubborn clogging): Gloves and 91% alcohol
  5. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Heating up water: 5 단계, 이미지 1/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Heating up water: 5 단계, 이미지 2/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Heating up water: 5 단계, 이미지 3/3
    • If possible, use hot distilled water.
    • If the water is dirty, get a fresh bowl - especially with sources like a coffee maker.
    • Before removing the printhead, hot water is needed. Remove the K-Cup holder and get a bowl of water.
  6. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Print a baseline image: 6 단계, 이미지 1/1
    • Print a test image as a baseline. A good image can be found here: SMPTE color bars.
  7. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Clean the printhead: 7 단계, 이미지 1/2 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Clean the printhead: 7 단계, 이미지 2/2
    • Alcohol should only be used as a last resort as it can damage the printhead seals! If you use alcohol, 3 water flushes are needed to purge the printhead fully!
    • Recommended circulation times: Alcohol: 5-10 minutes. Without alcohol: 15 minutes.
    • The water will get lighter as the ink breaks down, this is normal. If your clog is stubborn, an ultrasonic cleaner may help break it down.
    • Put the printhead in hot water. Repeat until the printhead is reasonably clean. Change the cleaning water frequently.
    • Wipe the printhead contacts and nozzles by hand to ensure these areas are dry.
    • Before reinstalling the printhead, let it air dry for ~3-4 hours. Using a fan may speed this step up.
  8. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Reinstall the printhead and ink: 8 단계, 이미지 1/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Reinstall the printhead and ink: 8 단계, 이미지 2/3 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Reinstall the printhead and ink: 8 단계, 이미지 3/3
    • Wait until the printhead is bone dry, or you will lose the existing calibration! While recoverable, this will be an expensive mistake, especially with non-XL carts (1/2 cart waste with non-XL, 1/4 with XL). Your printer will run a minor cleaning cycle after printhead installation ("printhead preparation"), but wastes far less ink.
    • Once the printhead is satisfactorily dry, reinstall the printhed and ink in the printer. Plug the printer in.
  9. Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Test the printer: 9 단계, 이미지 1/2 Gentle method - HP Photosmart Plus B210a Printhead Cleaning, Test the printer: 9 단계, 이미지 2/2
    • All ink cartridges must have ink left. If all else fails, get a DYE BASED refill kit and add ink to the cartridge set as needed. This will spare the printer from unnecessary printed damage. FAILURE TO DO THIS MAY RESULT IN PRINTHEAD DAMAGE; A NEW PRINTHEAD WAS ~$80; NOW EOL AND THE END OF YOUR PRINTER.
    • If you have a 5-color "photo" printer (C/M/Y/K/PK), print a photo from your phone or camera if you print photos regularly or run the SMPTE bar test as a photo.
    • After replacing the printhead, test the printer. Match the previous settings and check for improvement.
결론
If your printer is working correctly, it was just a clog. Persistent issues usually total out the printer as a unit.
다른 12명이 해당 안내서를 완성하였습니다.
첨부 문서
Nick
회원 가입일: 11/10/09
89,943 평판
안내서 52개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 9개
While/when soaking the printhead, I used a small intact artist's paint brush (no hairs falling out of it) to help loosen the globs of ink. I changed the water several times as there was a lot of ink.
Also, the first time I tried printing after soaking/cleaning the printhead (my issue was that the regular black cartridge showed it was NOT empty, but printing black documents wasn't working), I still had a blank page. Next I tried aligning the printhead but got a "failed," or similar, result. Next, I printed a "print quality report" from the printer's Tools menu and that seemed to be fine, so I tried printing the invoice I originally was having issues with, and voila, it worked!
Thanks.
Dave - 답글
Thanks this worked and all is well again
The one things that I had to do: I put the machine back together when it looked dry and the machine would not work. It refused the print head and complained that the ink packets were used. I tired it about 4 times with the same results. So I set it all aside and let it dry out over night. Wha La it worked. I put it all back together, the machine did it's thing and suddenly everything worked perfect.
Thanks again for saving me from having to buy a new machine.
Barbara - 답글
HI, I am glad to find your explanation. I have followed HP's instructions, which didn't include soaking the print head, but will try that, too. What I am having trouble with now is that the printer screen says that "the print head appears to be missing, not detected, or incorrectly installed". I've redone it 3 times with no change. Also, the HP instructions did not say to unplug it and leave the cover open, so I left it plugged in and put the cover down. Since the printer is not recognizing the head, I have no way of telling if the alignment settings are messed up or not. Do you have suggestions for getting the printhead to be recognized? Thanks a lot.
carinchapin - 답글
Thanks so much!! It worked! Never would have guessed!!
Helen Liss - 답글
I am using refilled cartridges for the Photo-smart 6520 all in one wireless (mainly) . I am trying to get the printer to not give me problems due to the chips being read by the system and knowing that they are previously used. I took the cartridges out last night and also the print head as described. There was a WHOLE LOT OF INK (mainly black) in several places inside the printer that I did not like. Even with the print head out, I had to continue to move the carriage and clean "leaked" drops of mainly black ink from the path on the metal part. I also had to carefully clean it from the white rollers. I cleaned so much ink from the print heat and it seems that the colors side it pretty much clean. It is the black side that concerns me. From underneath the print head, that nozzle seems to still have some dried ink there. I let it dry overnight, am in the process of a hard reset, and will be plugging it in again and inserting the cartridges during that process. I will try and check back for comments.
iceberg32 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 37
전체 시간: 45,257
