주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Giant Reign 2 Tube Replacement
필요한 것
    1. Giant Reign 2 Tube Replacement, Hex Screws: 1 단계, 이미지 1개 중 1개
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      댓글 쓰기
    2. Giant Reign 2 Tube Replacement, Axle Screw: 2 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement, Axle Screw: 2 단계, 이미지 2개 중 2개
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      댓글 쓰기
    3. Giant Reign 2 Tube Replacement: 3 단계, 이미지 1개 중 1개
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      댓글 쓰기
    4. Giant Reign 2 Tube Replacement, Front Wheel: 4 단계, 이미지 1개 중 1개
      • Pull the wheel from the fork.
      댓글 쓰기
    1. Giant Reign 2 Tube Replacement, Tube: 5 단계, 이미지 1개 중 1개
      • Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
      • Bike tubes come with one of two standard valve types: presta and schrader. These guides show the installation of a tube with a presta valve.
      댓글 쓰기
    2. Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 1개 Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 2개 Giant Reign 2 Tube Replacement: 6 단계, 이미지 3개 중 3개
      • Unscrew the cap covering the valve.
      • Remove the spacer that holds the valve in place against the rim of the wheel.
      • Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
      댓글 쓰기
    3. Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 1개 Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 2개 Giant Reign 2 Tube Replacement: 7 단계, 이미지 3개 중 3개
      • Slide the tire lever between the tire and the rim.
      • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
      • Insert a second tire lever adjacent to the first.
      • Slowly work one tire lever around the rim until the whole tire is loose.
      댓글 쓰기
    4. Giant Reign 2 Tube Replacement: 8 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 8 단계, 이미지 2개 중 2개
      • Press the valve through the rim of the wheel.
      • Remove the tube from the tire.
      댓글 쓰기
    5. Giant Reign 2 Tube Replacement: 9 단계, 이미지 1개 중 1개
      • Partially inflate the tube.
      댓글 쓰기
    6. Giant Reign 2 Tube Replacement: 10 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 10 단계, 이미지 2개 중 2개
      • Push the valve through the rim.
      • Push the tube into the tire all the way around the rim of the wheel.
      댓글 쓰기
    7. Giant Reign 2 Tube Replacement: 11 단계, 이미지 1개 중 1개
      • Push the bead of the tire back into place around the rim.
      • Make sure not to pinch the tube between the bead of the tire and the rim. Failure to do so may cause a pinch flat.
      댓글 쓰기
    8. Giant Reign 2 Tube Replacement: 12 단계, 이미지 1개 중 1개
      • Inflate the tube to the desired air pressure.
      • A suggested range of air pressure is located on the wall of the tire (formatted ##-##psi).
      댓글 쓰기
    9. Giant Reign 2 Tube Replacement: 13 단계, 이미지 2개 중 1개 Giant Reign 2 Tube Replacement: 13 단계, 이미지 2개 중 2개
      • Close the valve and replace the cap.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sterling Grande
회원 가입일: 10/08/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G14
4 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 39
전체 시간: 3,542
