주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Giant Reign 2 Wheel Spoke Replacement
필요한 것
    1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: 1 단계, 이미지 1개 중 1개
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      댓글 쓰기
    2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: 2 단계, 이미지 2개 중 1개 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: 2 단계, 이미지 2개 중 2개
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      댓글 쓰기
    3. Giant Reign 2 Wheel Spoke Replacement: 3 단계, 이미지 1개 중 1개
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      댓글 쓰기
    4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: 4 단계, 이미지 1개 중 1개
      • Pull the wheel from the fork.
      댓글 쓰기
    1. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 5 단계, 이미지 3개 중 1개 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 5 단계, 이미지 3개 중 2개 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 5 단계, 이미지 3개 중 3개
      • Twist and pull off the cap covering the tire valve
      • Twist off the spacer that holds the valve in place.
      • Push valve in toward wheel to release air pressure.
      댓글 쓰기
    2. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 6 단계, 이미지 3개 중 1개 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 6 단계, 이미지 3개 중 2개 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 6 단계, 이미지 3개 중 3개
      • Insert one tire lever between the tire and the rim.
      • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
      • Insert a second tire lever next to the first.
      • Slowly slide one tire lever around the rim until the tire is released from the rim.
      댓글 쓰기
    3. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: 7 단계, 이미지 1개 중 1개
      • Using your hand, pull the tube completely out of the tire.
      댓글 쓰기
    4. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: 8 단계, 이미지 1개 중 1개
      • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
      • Pull brake rotors off both sides of the wheel.
      댓글 쓰기
    5. Giant Reign 2 Wheel Spoke Replacement, Tire: 9 단계, 이미지 1개 중 1개
      • Pull the tire from the rim.
      댓글 쓰기
    6. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: 10 단계, 이미지 1개 중 1개
      • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
      • Using your fingers, pull off the old spoke nipple.
      댓글 쓰기
    7. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: 11 단계, 이미지 1개 중 1개
      • Push out the old spoke from the hub.
      댓글 쓰기
    8. Giant Reign 2 Wheel Spoke Replacement: 12 단계, 이미지 2개 중 1개 Giant Reign 2 Wheel Spoke Replacement: 12 단계, 이미지 2개 중 2개
      • Insert a new 250mm spoke into the hub.
      • Align the spoke with the spoke nipple in the rim.
      • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
      댓글 쓰기
    9. Giant Reign 2 Wheel Spoke Replacement: 13 단계, 이미지 1개 중 1개
      • Using an SW-1 spoke wrench, tighten the spoke.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Sterling Grande
회원 가입일: 10/08/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G14
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 2,834
