주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gigabyte P34G Battery Replacement
필요한 것
  1. Gigabyte P34G Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove all 15 screws on the underside of the laptop using a Phillips #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    댓글 쓰기
  2. Gigabyte P34G Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 4.5 mm screws using a Phillips #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
    댓글 쓰기
  3. Gigabyte P34G Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the wires down towards yourself to gently detach the connector from the main drive.
    • Save connector for reassembly later.
    댓글 쓰기
  4. Gigabyte P34G Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully lift the battery for removal and discard properly.
    • Replace with new battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
yeunghayden
회원 가입일: 05/01/15
841 평판
안내서 6개를 작성함
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 회원
CPSU-REGAN-S15S8G1
5 회원들
안내서 12개를 작성함
12가이드 댓글
Does anyone know where to find a replacement, or if you can fit the version 1 of this computer with a larger capacity battery from version 2?
tadej rezar - 답글 공유
Over at https://www.mysn.de/detail.asp?bestellnr... (don't mind their stock picture), they still sell the battery for the C404 (which is identical to the P34G v2). I just bought a new 61.25 Wh GNC-J40, manufactured in 2016/07.
M D - 답글 공유
Will it run without the battery or is it a required part of the circuit? I have a P35G V2 and I only use it plugged in anyway.
jens_lipponer - 답글 공유
The battery in my P34G v2 is pretty solidly stuck to the chassis. I don't really want to pull on it too hard but is this normal?
Donald Macaulay - 답글 공유
@jens_lipponer Yes it runs without the battery fine. I have my battery disconnected as it is really swolen and the laptop boots without a problem.
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 49
전체 시간: 20,394
