주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero+ LCD Battery Replacement
필요한 것
    1. GoPro Hero+ LCD Battery Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Battery Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      댓글 쓰기
    2. GoPro Hero+ LCD Battery Replacement: 2 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      댓글 쓰기
    3. GoPro Hero+ LCD Battery Replacement: 3 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      댓글 쓰기
    1. GoPro Hero+ LCD Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      댓글 쓰기
    2. GoPro Hero+ LCD Battery Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      댓글 쓰기
    3. GoPro Hero+ LCD Battery Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      댓글 쓰기
    4. GoPro Hero+ LCD Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kyle
회원 가입일: 08/27/15
219 평판
안내서 1개를 작성함
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G4
4 회원들
안내서 20개를 작성함
13가이드 댓글
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - 답글 공유
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - 답글 공유
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - 답글 공유
not even amazon?
Mary D'Alesandro - 답글 공유
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 30
지난 30일: 196
전체 시간: 42,484
