주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement
필요한 것
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      댓글 쓰기
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 2 단계, 이미지 2개 중 1개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      댓글 쓰기
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 3 단계, 이미지 2개 중 1개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      댓글 쓰기
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      댓글 쓰기
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      댓글 쓰기
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      댓글 쓰기
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      댓글 쓰기
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 1개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 2개 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 3개
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
      댓글 쓰기
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
      댓글 쓰기
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
      댓글 쓰기
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Gently lift the microSD/Micro USB assembly up and out of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Shariyf Mitchell
회원 가입일: 08/27/15
207 평판
안내서 1개를 작성함
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G4
4 회원들
안내서 20개를 작성함
2가이드 댓글
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - 답글 공유
Very helpful guide
Ninigo Marine Contractor - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 42
전체 시간: 4,260
