주요 콘텐츠로 건너뛰기
GoPro Hero+ LCD Motherboard Replacement
필요한 것
  1. GoPro Hero+ LCD Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
  2. GoPro Hero+ LCD Motherboard Replacement: 2 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Motherboard Replacement: 3 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
  4. GoPro Hero+ LCD Motherboard Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Motherboard Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero+ LCD Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
  8. GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 1개 GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 2개 GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 8 단계, 이미지 3개 중 3개
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Motherboard Replacement, Image Sensor: 12 단계, 이미지 1개 중 1개
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
  13. GoPro Hero+ LCD Motherboard Replacement, Motherboard: 13 단계, 이미지 3개 중 1개 GoPro Hero+ LCD Motherboard Replacement, Motherboard: 13 단계, 이미지 3개 중 2개 GoPro Hero+ LCD Motherboard Replacement, Motherboard: 13 단계, 이미지 3개 중 3개
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
  14. GoPro Hero+ LCD Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
  15. GoPro Hero+ LCD Motherboard Replacement: 15 단계, 이미지 3개 중 1개 GoPro Hero+ LCD Motherboard Replacement: 15 단계, 이미지 3개 중 2개 GoPro Hero+ LCD Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matthew Tinkey
회원 가입일: 08/27/15
922 평판
안내서 4개를 작성함
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G4
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 5,036
