주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero 3 Silver Image Sensor Replacement
필요한 것
    1. GoPro Hero 3 Silver Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pull back on the tab on the back of GoPro to open the battery cover.
      댓글 쓰기
    2. GoPro Hero 3 Silver Image Sensor Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the battery out using the tab.
      댓글 쓰기
    1. GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 3 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement, Image Sensor: 3 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      댓글 쓰기
    2. GoPro Hero 3 Silver Image Sensor Replacement: 4 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement: 4 단계, 이미지 2개 중 2개
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      댓글 쓰기
    3. GoPro Hero 3 Silver Image Sensor Replacement: 5 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement: 5 단계, 이미지 2개 중 2개
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      댓글 쓰기
    4. GoPro Hero 3 Silver Image Sensor Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement: 6 단계, 이미지 2개 중 2개
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      댓글 쓰기
    5. GoPro Hero 3 Silver Image Sensor Replacement: 7 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement: 7 단계, 이미지 2개 중 2개
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      댓글 쓰기
    6. GoPro Hero 3 Silver Image Sensor Replacement: 8 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Image Sensor Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
      • You should now be able to remove the image sensor by simply pulling it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jose Villa
회원 가입일: 04/01/15
297 평판
안내서 1개를 작성함
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 21개를 작성함
2가이드 댓글
After the sensor has been replaced, does the camera need any catibration?
enrilazaro - 답글 공유
Your pictures are really dark.
Nick Ruiz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 36
전체 시간: 2,406
