주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero 3 Silver Motherboard Replacement
필요한 것
    1. GoPro Hero 3 Silver Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Pull back on the tab on the back of GoPro to open the battery cover.
      댓글 쓰기
    2. GoPro Hero 3 Silver Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the battery out using the tab.
      댓글 쓰기
    1. GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      댓글 쓰기
    2. GoPro Hero 3 Silver Motherboard Replacement: 4 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      댓글 쓰기
    3. GoPro Hero 3 Silver Motherboard Replacement: 5 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      댓글 쓰기
    4. GoPro Hero 3 Silver Motherboard Replacement: 6 단계, 이미지 2개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      댓글 쓰기
    5. GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 3개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 3개 중 2개 GoPro Hero 3 Silver Motherboard Replacement: 7 단계, 이미지 3개 중 3개
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
      댓글 쓰기
    6. GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 3개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 3개 중 2개 GoPro Hero 3 Silver Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      • The media adapter is attached to the motherboard via 3 screws:
      • x1 T4 Torx
      • x2 Phillips #00
      • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
      • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
      댓글 쓰기
    7. GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 3개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 3개 중 2개 GoPro Hero 3 Silver Motherboard Replacement: 9 단계, 이미지 3개 중 3개
      • Use the spudger to lift the black tab up to unlock.
      • Then remove LCD screen connector by sliding out.
      댓글 쓰기
    8. GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 3개 중 1개 GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 3개 중 2개 GoPro Hero 3 Silver Motherboard Replacement: 10 단계, 이미지 3개 중 3개
      • Using the Phillips head bit, remove the silver screw near the top edge of the board.
      • Separate the LCD assembly by pulling it away. You should have the bare motherboard!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brian Alvarez
회원 가입일: 04/02/15
1,439 평판
안내서 6개를 작성함
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G7
3 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 44
전체 시간: 9,244
