주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GoPro Hero Battery Replacement
필요한 것
  1. GoPro Hero Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    댓글 쓰기
  2. GoPro Hero Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    댓글 쓰기
  3. GoPro Hero Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
    • The battery is glued to the plastic so some force might be necessary.
    • Be careful not to damage the battery to avoid releasing dangerous chemicals.
    댓글 쓰기
  4. GoPro Hero Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from the GoPro.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
River Drake
회원 가입일: 04/02/15
1,065 평판
안내서 5개를 작성함
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G2
4 회원들
안내서 18개를 작성함
20가이드 댓글
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - 답글 공유
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - 답글 공유
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - 답글 공유
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - 답글 공유
now add go pro to rice for a day and pray.
chadd23 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 42
지난 30일: 279
전체 시간: 83,822
